RV.Net Open Roads Forum: Full-time RVing: Baking soda in toilet?
Search only in Full-time RVing
Open Roads Forum  >  Full-time RVing
 > Baking soda in toilet?
toyqt
Camphosting somewhere
Posted: 10/10/12 03:11pm Link  |  Print  |  Notify Moderator
Was just reading up on some home tips etc., and wondered whether it would hurt anything to put baking soda down the toilet to help with odor? We have tried numerous brands of chemicals, and nothing works well. Just to be clear, we are FT'ing, workamping, and we leave our grey tanks open, but black closed.
Thanks in advance!
Me, my hubby, and our new pup, a mini dachshund named Fred
2008 Keystone Cougar
2001 Chevy 3500 Dually 8.1L Vortec
Dick_B
Palos Heights, IL USA
Posted: 10/10/12 04:00pm Link  |  Print  |  Notify Moderator
Shut off the water and open the toilet valve and look down there. We had a lot of accumulated `dirt' just below the toilet and above the tank. Took a brush to it and the dirt and smell went away.
Ditto the bathroom sink had some accumulated `stuff' just below the drain which smells a lot better since we cleaned it out also.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
SteveAE
Bend, Oregon
Posted: 10/10/12 04:04pm Link  |  Print  |  Notify Moderator
I can't speak to baking soda in RV tanks (we don't use any chemicals in our RV tanks and don't seem to have any issues).
However, I can address smaller holding tanks used for multi-day river trips. Baking soda is perfect. There are almost no odors, even during week long hot weather trips. Big difference though is there is no (or very little) fluid in river toilets (we urinate in the river or on wet ground....as per most river management agency rules and we don't add any additional water until the last day prior to dumping). So I am not sure if the baking soda wouldn't be diluted too much by the water in the black tank. Hey, it can't hurt to try though.
Maybe the best solution is to figure out why you are getting odors in the first place. Perhaps a larger, or higher, vent would help?
Good luck,
Steve
BarbaraOK
On The Road
Posted: 10/10/12 04:34pm Link  |  Print  |  Notify Moderator
Baking soda is great down the toilet, helps buffer the solution,etc. i use it for scrubbing the toilet, enough grit so you don't need to use anything else if you scrub frequently.
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II (2002 Alpine 36 MDDS) ">
Mischief (2004 Subaru Forester Toad) ">
FMCA - F337834, SKP #90761
Our Blog
Francesca Knowles
Port Hadlock, Washington
Posted: 10/10/12 04:53pm Link  |  Print  |  Notify Moderator
I've used baking soda in a porta-potty, too...BUT
I'm pretty sure that the amount of soda required to have any effect on a full sized RV black tank would be huge.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Old-Biscuit
Verde Valley
Posted: 10/10/12 05:03pm Link  |  Print  |  Notify Moderator
More water....especially when flushing solids.
Other than a brief whiff when flushing toilet (especially if any fan is exhausting) you should have NO odors from waste tanks (black or grey) if system is working properly ie:
Water is in toilet bowl (vapor barrier)
Toilet floor flange is good (mechanical barrier)
Sink/shower 'P' traps hold water (vapor barrier)
Air admittance valves open/close correctly (located on grey waste drain lines to prevent 'P' traps from being sucked dry when draining grey tanks....located under sinks...if not closing odors from grey tank can come back into RV)
Waste tank vents are free & clear....properly venting above roof line
Washing machine (if plumbed for one)..'P' trap holding water
Water is the key.......flushing toilet, draining tanks (high level to flush & carry solids out), rinsing tanks.
toyqt
Posted: 10/10/12 06:15pm Link  |  Print  |  Notify Moderator
Thanks for all of the info y'all, as usual, you've come through for me!
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 10/10/12 06:50pm Link  |  Print  |  Notify Moderator
Baking Soda is a great scouring powder for hard plastic surfaces. It works wonderful for ice chests / coolers / refrigerator interiors and especially the rubber seals around a refrigerator. It's consumable, so it won't hurt or contaminate or poison you or pet. It's also a deodorizer. But depending upon the item, it could take a lot. An RV holding tank would probably take a lot. However, if the tank was empty and you added a couple gallons of water and a box of Arm and Hammer down the toilet, then go drive around and let it all slosh around, it will probably do a pretty good job of eliminating odors. And you won't have to dump it either.
Baking Soda works pretty good on cat litter to eliminate odors and extend the life of cat litter. It's used in washing machines to help eliminate odors and boost washing power. So, yes, it will work in your black tank, if you make it strong enough to cover the space.
And did I mention, it makes a really great scouring powder on surfaces that touch food?
DutchmenSport
2013 Outback 298RE
2014 Chevy Silverado 3500 Duramax Dually
1400 / 14000 Equal-i-zer Weight Distribution
2 Dachshunds, 1 cat, 2 old folks and lots of love!
Trap
Alberta
Posted: 10/11/12 08:42pm Link  |  Print  |  Notify Moderator
The best thing I found for controling tank odor is to always travel with a 1/3 of a tank of water, sometimes we add some Dishwasher soap and calgon to help in cleaning, it's the sloshing around of the water while you travel that really goes a long way in keeping tanks clean. Quite often we drain the tanks when we arrive at our next destination, then add about 5 gallons to the black tank before using.
smurf
South Dakato And Wa.
Posted: 10/12/12 01:48pm Link  |  Print  |  Notify Moderator
WE have full timed for 10 years. After sitting for a longtime we put in some water then 2-3 bags of ice cubes to sloush around till we dump cleans out the black water tank. Works great !!!
2004 GMC HD 4x4 Douramax with Allison transmission loaded.
20005 36ft. Everest W/ 4 slides loaded.
Full timing and having fun
No matter where you go there you are
Papa Smurf driver
Mama Smurf Professional Passenger
