RV.Net Open Roads Forum: Truck Campers: Hot water heater by-pass valve
 > Hot water heater by-pass valve
Ziphead2
Newark
Posted: 10/18/12 05:28pm Link  |  Print  |  Notify Moderator
I can find the shut off valve for the cold water supply to the hot water heater but not the hot water discharge. When I send the pink stuff thru the lines is this going to be a problem. Do some mfrgs use a check valve instead?
Artum Snowbird
Campbell River, B.C., Canada
Posted: 10/18/12 05:47pm Link  |  Print  |  Notify Moderator
Answer, YES! The check valve is about 3/4 of an inch long. What you need to do is shut off the cold water intake, open the bypass so cold water is going directly to your hot water taps.
Now drain the HWT and then pressurize the system with water. This will ensure that your check valve is working. Once you have one that is stuck open, and you dump a few gallons of anti freeze out the HWT drain valve, you will realize the importance of this check.
mike
Mike and Carole
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers
CloudDriver
New Jersey Shore
Posted: 10/18/12 05:51pm Link  |  Print  |  Notify Moderator
Our Minnie has a single valve bypass setup for the water heater. There is a check valve in the hot water outlet. The one valve is a 3-way valve. A 1/4 turn of the valve handle switches between normal use and bypass. In the picture below, the valve is set to bypass.
2003 Winnebago Minnie 24F - Ford E-450">
Tango, AE7UI
W Jordan, UT
Posted: 10/18/12 06:42pm Link  |  Print  |  Notify Moderator
Our Lance camper had a 3 valve setup to bypass the water heater which was located below the kitchen sink and easy to access.
The fifth wheel only has a single 3 way valve aand it is located behind a drawer which must be pulled to gain access.
It is a cumbersome method but patience goes a long way.
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
AplusMM
St Louis Metro
Posted: 10/18/12 08:43pm Link  |  Print  |  Notify Moderator
FWIW, I'm not a fan of the check valves, I'd rather see 3 valves. You almost never see quarter turn ball valves fail but check valves fail all the time. Just my opinion.
