RV.Net Open Roads Forum: Class A Motorhomes: Electrical question
 > Electrical question
psmoore
Illinois
Posted: 10/30/12 10:10am Link  |  Print  |  Notify Moderator
I have a 36 Winnebago Brave. I have it plugged into an outlet in my garage. This may be really dumb, but why do I have electic to my tv's and microwave, but not to lights, heater, water pump, etc? Not sure what other information you may need to try and help me.
This unit is new to me, and I know it has an electrical management system. The power cord in the back does not plug into anything. I have reset all the GFCI outlets and none of the breakers are tripped.
Thanks for any help you might give me!
Paul and Susan - 4 kids
2001 Winnebago Brave 35C
psmoore
Illinois
Posted: 10/30/12 10:17am Link  |  Print  |  Notify Moderator
I do know that my batteries are dead, but not sure why I would have to have battery power when hook to electricity.
Dick_B
Palos Heights, IL USA
Posted: 10/30/12 10:18am Link  |  Print  |  Notify Moderator
TV's and M'wave work off 110 VAC the lights etc. work off 12VDC. Do you have a charged battery?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
downtheroad
Pacific Northwest
Posted: 10/30/12 10:19am Link  |  Print  |  Notify Moderator
Most if not all of your lights, your furnace and water pump operate on DC current - your batteries not on AC current.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
2ndhom
Eugene, Oregon
Sounds like anything with 12 volts is not working. Does the coach have fuses? Have you checked and actuated the breakers? Is there a master switch for just the 12 volt items inside the coach?
siggyd777
Northern Illinois
Posted: 10/30/12 10:22am Link  |  Print  |  Notify Moderator
Your Converter (Charger) may be bad,not charging the house batteries.
How old are the house batteries,have they been serviced (distilled water)?
Bad batteries can damage the converter.
Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
AllegroD
Outdare
Posted: 10/30/12 10:26am Link  |  Print  |  Notify Moderator
It sounds like your entire 12v is dead. Do you have a converter? This converts 120 volt to 12 volt for power to your 12 volt systems (lights, heater (has 12v control board) and water pump. Have you checked the 120 volt circuit breaker that feeds the converter? Do you have a voltmeter? If the converter is on, are you getting power out of the 12 volt side? Check the 3 wires to see that they are connected well. This includes the ground, bare or green wire. Make sure the ground is well connected to the frame. If all of this is well, and your batteries are dead, I would disconnect them, as they might be drawing down all of your power.
Tell us what you found.
Clay L
Palisade CO
Posted: 10/30/12 11:02am Link  |  Print  |  Notify Moderator
Has the battery disconnect switch (often by the door) been switched to the disconnect position?
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
psmoore
Illinois
Posted: 10/30/12 11:05am Link  |  Print  |  Notify Moderator
My batteries are dead. All three batteries are in the step, 2 for the coach and the engine battery. I tried to start it and nothing and tried to start it off the coach batteries and nothing.
The switch right inside the door didn't make a difference either way on or off. But I'm thinking that's because the batteries are dead.
I am trying to winterize it, and can't get the water pump on. I did get the water heater tank drained at least.
tommy g
West Georgia
Posted: 10/30/12 11:11am Link  |  Print  |  Notify Moderator
This is most likely a converter issue. Check for AC power to converter or blown fuses/tripped breakers DC out.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
