recycler
michigan
hate to be a wet blanket, but if your going to the truck for length reasons a long bed crew cab is about 25 ft long so you will not gain much there...one of those double decker trailers might be a better route..
1968 franklin 11fk
back to my 93 cummins
thordahl
McHenry, IL
Another reason to change is that I am not able to use the tandem tow to haul the ATV's from the camp site to the ride sites. The length of a toad vs a tandem tow with a car on the back is much less of a issue. With my current system it gets tight in sharp turns since the trailer wheels are so far back not to mention the rear wheels of the Saab.
At 65 feet at least I will be legal in more states. Not to mention the issues we have with finding camping that will take this current length. With a toad worst case is to unhook and follow in. Cant do that with a tandem tow that has a tongue weight of over 1100 LB when the car is removed & quads still on. The weight of the car when installed offsets the tandem tow to a TW of 420 lb. Only real way to move the tandem tow is to remove everything.
The reason why I am thinking a flatbed pick up vs like below is there will be less height for loading also I feel with a setup like below it would be more top heavy when driving.
2 unit on back of pick up
I am thinking about something like this.
edited 11/15/12 07:11am by thordahl *
2005 Fleetwood Discovery 39S
zb39
slippery rock
My manual for the 2011 dodge says towing 4 wheels down is no problem. No distance or speed limitations.
05 Tiffin Zephyr
07 Dodge Caliber toad
Artic Fox 1150 slide
2011 DRW 3500 Crewcab Longhorn
pnordan
North Carolina
I tow a Dodge 1500 4x4 quad cab, 5.7 hemi. Unless you have to have the 3/4 ton, the 1/2 tons should be much lighter. Don't trust the published curb wt. The 1500 4x4 had published wt of around 5300#, actual when I got it home was close to 6100#
It is easy to set up and tow.
Paul & Kristina
Lucy & Curly
2004 American Coach Tradition
2004 jeep Grand Cherokee
tporter
I tow a Jeep or if I need to haul something a 2006, Chevy 2500, HD, 4x4, crew cab, long bed, with the duramax engine. The 4x4s have the neutral switch for the transmission so all I have to do is push the button while the truck is in neutral, go back to park, and take the keys out. The truck has a brake system (due to weight) that works off of the motorhome air system. This takes an air line coming from the coach to a small air tank mounted in the engine compartment. From here the air line has a quik connect in the cab for the controller that pushes the brake pedal. It sounds like allot but is an easy system and works great. If you are interested in pictures I can send you some.
Our coach is a 2003, Fleetwood Discovery, 38' long, with a Cat c-7, 330HP motor. No problems stopping or starting although I can tell the additional weight is back there.
hipower
Western PA
I've towed my Silverado (2009) over 25,000 miles with no problems. It works exactly as others have stated. Key off, transmission in park, transfer case in neutral.
My only problem is my memory, sometimes I find it neccessary to pull out the owners manual to refresh my memory of the exact steps and sequence to put the transfer case in and out of gear. It's tough getting old(er). LOL
rjstractor
Auburn, WA
The GM crew cab long bed pickup is 21 feet and change, not 25 so it's not really that long. Not sure about the Ram because I couldn't find the dimensions but it's probably close to the same. With the tow bar the truck will be close to 25-26 so your overall length of 65 sounds about right. I'm thinking that with 1500 lbs of atvs and an aluminum bed a 1500 series truck will not cut it at all if you plan on having any capacity left over for passengers.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
2006 Ford Escape Hybrid
1998 Saturn SL2 toad
2012 VW Jetta S
Diplomat Don
Moorpark, Ca
If you go with a 3/4 ton in the Chevy or Dodge, I would think that if you bought it with a long bed (8'), you could put both quads in the back of the stock bed. One standing up and the other one on it's back. I just ordered a set of tailgate supports for my truck that will allow me to drive a Polaris RZR into the bed of my shortbed Chevy that I tow. The supports strengthen the tailgate so it doesn't drop when the rear wheels of the RZR are sitting on it during travel.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
zman-az
Northern AZ
My 2010 Ram 2500 crewcab cummins is towable 4 down although I have not done it. This truck is huge and heavy but you can't beat a diesel for towing stuff. That flat bed option looks nice, not a fan of the rack on the top of the truck bed. I would test the Chevy and Dodge and compare the two.
