RV.Net Open Roads Forum: Class A Motorhomes: Squeaky door
 > Squeaky door
MSHappyCampers
Columbus, MS
Posted: 11/18/12 02:45pm Link  |  Print  |  Notify Moderator
The door on my Monaco Windsor squeaks on the road. I think it is the rubber seal around the door. Anyone know of something I can put on the rubber to stop the squeak that will not rub off on clothing if we should brush against it?
Joe & Annette
2002 Monaco Windsor 40PBT
dougrainer
Carrolton, Texas
Posted: 11/18/12 03:40pm Link  |  Print  |  Notify Moderator
Rubber squeaking on a door is extremely rare. White Grease the latch pins and lock. Doug
gbopp
The Keystone State
Posted: 11/18/12 03:46pm Link  |  Print  |  Notify Moderator
Silicone Spray
Mr.Mark
Out West and Mid South
Posted: 11/18/12 04:31pm Link  |  Print  |  Notify Moderator
Joe, I thought it was our door squeaking too and would have sworn that it was the screen door vibrating against the exit door. It was the electric step cover vibrating. It sure sounded like it was the door.
Also, does the Windsor have the inflating door seal? It could be that you need to adjust the valve that is located in the genny compartment. Just a thought.
MM.
Mr.Mark
2015 Prevost Liberty Coach
2017 Lincoln MKX AWD
Executive
Posted: 11/18/12 05:10pm Link  |  Print  |  Notify Moderator
I was thinking the same thing, Mark. Don't know if the Windsor came with the air seal. I know all coaches from the Camelot up did. To the OP, if your coach has the air seal, a simple adjustment on that will fix it. Just make sure it IS the DOOR before you go messing with it, don't assume.......Dennis
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
MSHappyCampers
Columbus, MS
Posted: 11/19/12 07:10am Link  |  Print  |  Notify Moderator
MM.
No, mine doesn't have the inflating seal. What did you do about the step vibrating?
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
Posted: 11/19/12 07:26am Link  |  Print  |  Notify Moderator
I was getting a squeal sound from the door latch (meal on metal). I now use a 3-5" of black tape around the striker post.
Eric
2014 Enterra 314RES (Cruiser RV) TT, Equal-i-zer 12K, Honda 2000 Genny
2014 Ram 1500 Quad Short Bed, 5.7L Hemi, 8 speed auto, 4x4, Line-X
FQCC/Camping Quebec, KOA, Good Sam
ljhl
Houston,Tx
Posted: 11/19/12 09:58am Link  |  Print  |  Notify Moderator
I had a loud squeak in the area of the entry door that would come and go....with the help of my grandkids (who hear well) I was able to determine that the squeak was coming from the hold-open mechanism mounted on the door top. A little bending and lubrication and the squeak is gone.
2007 Dutch Star 4023
Subaru Forester Toad
A mutt named Arvee
MSHappyCampers
Columbus, MS
Posted: 04/15/13 02:39pm Link  |  Print  |  Notify Moderator
Well, I finally got around to working on this problem. First I tried lubricating the rubber seal around the door because I was so sure that was where the squeaking was coming from. WRONG! [emoticon]
Eric, you were absolutely right! I wrapped electrical tape around the latch bolts and the squeaking is GONE!
Thanks to all for your suggestions! [emoticon]
 > Squeaky door
