RV.Net Open Roads Forum: Class A Motorhomes: power inverter
 > power inverter
dale1946
Avon, IN
Posted: 12/18/12 11:51am Link  |  Print  |  Notify Moderator
To power an A/C unit 13,500 BTU what size power inverter does one need and how many house battery. What type of power inverter and battery do us need also?
2oldman
Palm Springs
Posted: 12/18/12 12:21pm Link  |  Print  |  Notify Moderator
2000w inverter, 6 golf car batteries.
But you won't be able to do this for more than about 1/2 hour. Forget it.
harold1946
surprise Az.
Posted: 12/18/12 12:31pm Link  |  Print  |  Notify Moderator
For the most part it is not feesable to run an ac unit with battery power through an inverter without a tremendously large battery bank.
One would need to run the genny or be hooked to shore power.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
jhilley
Buxton, ND
Posted: 12/18/12 12:26pm Link  |  Print  |  Notify Moderator
And even that might not start the AC. You will need to use a generator to run you AC. If you don't want to use the on board generator, look at inverter models from honda, Yamaha and others.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
pianotuna
Regina, SK, Canada
Posted: 12/18/12 04:14pm Link  |  Print  |  Notify Moderator
Hi,
Four 8D 12 volt AGM batteries wired in a balanced manner and a 2000 watt inverter--preferably pure sine wave. The problem is, even if you can run the air conditioner for a while, that the battery bank needs to be recharged.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
mena661
Posted: 12/18/12 04:21pm Link  |  Print  |  Notify Moderator
Also, not all 2000W inverters will be happy with that continuous high amp draw either. Some have reported burning theirs up running the A/C. You'll need a high quality, beefy inverter.
Trojan L16 6V's 740 Amp-hours
harold1946
surprise Az.
Posted: 12/18/12 04:35pm Link  |  Print  |  Notify Moderator
I do not understand why anyone would imply it is possible "for a while". You would be risking destroying the batteries, ac compressor, inverter, or all of the above.
Do not attempt to do so, even with 4 8D AGM batteries.
pianotuna
Regina, SK, Canada
Posted: 12/18/12 04:48pm Link  |  Print  |  Notify Moderator
Hi harold,
Do give us an example of a destroyed (quality) inverter. I load mine up with well over 1500 watts (continuous) on a regular basis and have done so since May 2009. It is true mine is a MSW inverter (rated for use with electric motors) and also true that it can only do 2500 watts for thirty minutes. The only item that troubles my inverter is the 1591 watt microwave. Sometimes I have to turn on something else first, to "wake up" the inverter.
Actually 2 group 31 12 volt AGM batteries could run an air conditioner. Just not for very long, and there is still the recharge issue, no matter what the bank size is.
I am assuming proper gauge wiring in a balanced manner on the DC side of the equation and a modern 13500 air conditioner (mine draws 960 watts)
If the OP wants to do it a 3000 watt Go Power pure sine wave unit may be a better choice than a 2000 watt.
* This post was edited 12/18/12 05:04pm by pianotuna *
harold1946
surprise Az.
Posted: 12/18/12 05:42pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi harold,
I am not aware of any charger that would be able to recharge a battery bank fast enough supply power to run an ac.
The OP never stated the size of the battery bank or the size and make of the inverter, so everything in you statemant is only guesswork.
Guess I would have to agree that it may be possible to do for a very limited time if one were willing to risk the consequences.
Quality inverters come in all ratings from 300 watts up. The wattage is not a measure of quality. I did not say it would destroy the inverter. I listed it as any of three possible items that could be destroyed.
Without the knowledge of the onboard equipment I would not indicate one should even try. To do so is giving bad advice.
How long can you run your ac with your 875 AH battery bank?
Amps x Volts + watts, do the math.
* This post was last edited 12/18/12 06:05pm by harold1946 *   View edit history
bluwtr49
Green Valley, AZ
Posted: 12/18/12 06:11pm Link  |  Print  |  Notify Moderator
Lot easier to run the gen set for the AC unit than run it to recharge the batteries every 30 minutes. An inverter is simply no designed for this application.
Your AC unit needs ~13 amps at 120 VAC...this means you need to supply 150 amps from the batteries minimum. So, even will 1500 AH of battery capacity it would only take 30 minutes to discharge than to 50%.
Let's see, 1500 AH with 230 AH batteries, you would need 8 than recharging at 100 amps would take ~10 hours or so. Doesn't pencil in my book. Just run the gen set for AC and same a whole lot of bother.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
 > power inverter
