RV.Net Open Roads Forum: Class A Motorhomes: Best TOAD for 4 Down Towing?
 > Best TOAD for 4 Down Towing?
Page of 6
RVpullinGuy
Utah
Posted: 12/20/12 10:47pm Link  |  Print  |  Notify Moderator
I've decided FOR ME the best way to tow a TOAD is 4 down. In your experience and wisdom, what vehicle do you recommend as the best for 4 down towing for simple transportation once arrived at destination? What factors are important to you in this discussion?
Thanks!!
RVpullinGuy
2006 Chevy 2500HD Duramax/Allison CC SB
2005 Sierra T28 Toy Hauler
RZR XP41K, YamRaptor700, KawiKFX700, (2)Hon400Ex, Hon250EX, SuzLT80
Trap
Alberta
Posted: 12/20/12 10:54pm Link  |  Print  |  Notify Moderator
Well my vote is for the Jeep Liberty or Wrangler, you have a great vehicle to go exploring with, and there one of the easiest to tow. Hook up, put the transfer case in neutral, the transmission in park, and if 2008 and newer, just remove the key and your good to go.
No need to stop and start the engine and run the transmission through the gears. No battery cables to disconnect. About as simple of a plug and go as you can get.
Tom/Barb
Oak Harbor, Wa
Posted: 12/21/12 12:00am Link  |  Print  |  Notify Moderator
We towed our old type 1 baja bug for a very long time and never had a speck of trouble. we now have a wrangler
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JK toad.
rondeb
Pacific Northwest
Posted: 12/21/12 12:18am Link  |  Print  |  Notify Moderator
We have 2 different toads. One is a Mazda Miata Convertible and the other is a Honda CRV
Both of these are fantastic Toads.
jerseyjim
New Jersey
Posted: 12/21/12 02:26am Link  |  Print  |  Notify Moderator
I "toad" a 2007 Chevy HHR automatic. Pull a 2 amp fuse, put it in "N" and off y'go. I also "toad" a 2011 Ford Ranger pickup, automatic and 4WD. A bit more involved, you must buy a "Ford Only" "Transfer Case Disconnect Kit", and that works just fine,too.
The "best"....it's what you want...PROVIDING the car/truck CAN be towed 4 down with little or no modification.
Gotta research the subject. Pick a vehicle that can do it. Then, check, say, "BlueOX" to make sure a "baseplate" is made for the particular vehicle. Then buy the towbar, electric hookup wires...and off y'go.
Brake Buddy? (or something similar?) ANOTHER 900 bucks...but your choice IF you're towing a real heavy (4000+ pound, for instance) vehicle. Otherwise, if you're comfortable, not needed. Legalitiy? Another topic. Personally, I don't run with one.
Stoplights and turn signals: my 2007 HHR has the diode setup. Works fine. My 2011 Ranger? Nope. For that I use the magnetic lights. RV dealer told me the newer cars (like my Ranger) the diodes can send a (false) alarm of some kind to the computer. Something y'don't need.
trop-a-cal
Palm Coast Fl
Posted: 12/21/12 02:48am Link  |  Print  |  Notify Moderator
You save by not needing a braking system on vehicles under 3000 Lbs. They tow easier too. It also is easier to buy a vehicle with a transmission that does not require a seperate cooler for towing. Many GM transmissions and Honda have them.
n5tc
Salado, Texas
Posted: 12/21/12 04:14am Link  |  Print  |  Notify Moderator
Honda CR-V
Tom and Judith and Yappy Schnauzer Sable
2010 Allegro 32BA
Honda CR-V Tow Car
egshswinger
same
Posted: 12/21/12 04:29am Link  |  Print  |  Notify Moderator
can you not tow any kind of car or pickup as long as the drive shaft is disconected from the rear end, because there is nothing turning execpt for the rear end. I don't know but it sounds good.
Happy Traveling
May God Bless All
Eugene
2002 Silverado 2500HD Duramax
2004 Montana 3670RL
Full Timer as of 11/1/13
Snomas
Sedona, AZ
Posted: 12/21/12 05:13am Link  |  Print  |  Notify Moderator
We tow a 2012 Explorer. Like the larger size vs the smaller vehicles. Just shift into Neutral and go. Towed a 04 Odyssey for 8 years. Everyone has a different opinion on which is the best to tow 4 down. You will have to weigh what is important to you and go from there. Fortunately there are many vehicles out there to chose from. By the way the new Explorer is a great vehicle!!! IMHO Good luck!!!!
2002 DutchStar 350 Cummins/Spartan Chassis, 2012 Ford Explorer
RV CONUS
The Silver State
Posted: 12/21/12 05:29am Link  |  Print  |  Notify Moderator
Towed a 2008 Jeep Liberty for 4 years
Now towing 2013 Chevy Sonic.
Like them both, but for different reasons.
Both easy setup and go.
2006 Allegro Open Roads 34WA
2015 GMC Terrain
2009 Blue OX Aventa LX
2009 Brake Buddy Classic
Page of 6
