scarpa
Destin, Fl.
Does anyone know how to tell if the diesel engine block heater is on or off? The toggle switch is in the electrical panel in the BR but isn't marked on/off. Asked the dealer and he just shook his head.
Rob
2012 Fleetwood Providence
2011 Jeep Patriot Toad (on Dolly)
USAF and Govt Retired and Lovin it!!
2012 Fleetwood Providence, 380HP Cummins
2011 Jeep Patriot (on tow dolly)
USAF and Govt Retired and Lovin It!!
nor-easter
On The Road Again
I have a volt meter plugged into the socket next to the door where the control switch is located. If I reach into the cabnet and flip the switch I can detect the voltage change on the meter. I also check the amp meter on the power panel and can see the load increase when I switch on the engine block heater. When I first purchased the coach the heater was unplugged in the cellar compartment. After I plugged the heater in, the meters told what was going on.
Good Luck
Happy Trails
Capt. Chet
03 Journey DL 39.5 w/330 CAT and bells & whistles!!!!
Toad is a 04 Malibu
Full timing
Out Door World Elite/ Thousand Trails/ Pass Port America
FMCA f10045d
Mr.Mark
California/Tennessee
Rob, ours is on the dash and lights up when activated. I would think if the toggle switch is pushed down on the upper part it is in the 'on' position. Can you look at the amp reading on your system?
Just wondering what your manual says about the switch.
Good luck,
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
pianotuna
Regina, SK, Canada
Hi,
Plug in. Turn the switch to where you think it is on. Listen for the sizzle of the water. It will happen in under a minute.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
scarpa
Destin, Fl.
Manual never mentions the switch.
Am heading south and stopping by Lazy Days. Hopefully, they can tell me. My concern is it may have been on for last 6 month when I purchased it.
Thx,
Rob
ScottG
Bothell Wa.
pianotuna wrote: Hi,
THere's your answer. Fool proof and low tech ~ just listen for the sizzle, you can't miss it.
Scott, Grace and Wesly
H0NDA eu2000i
tony lee
Mexico. Next stop Iceland. Then Patagonia
Unplug the block heater.
Plug a desk lamp in.
See which position lights the lamp
Tony
Lots of photos with comprehensive captions at MY PICASA Album
Spotwalla map of our travels - Our Travel map
Ivylog
Blairsville, Ga. USA
What Tony is saying is that there is a outlet in the engine compartment where the block heater plugs into a normal 120V outlet. Check for voltage there.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
JamesBr
Manassas, VA
On my panel I have a dedicated circuit breaker labeled block heater. All it really does is control the GFCI outlet in the motor area. I use that outlet for other things too if I need power at the back of the RV for something. I plug and unplug the block heater as needed and only use the breaker to control it when im traveling in cold conditions like next weekend (at least till I get south enough its not needed.)
Mr.Mark
The engine 'outlet'.... That's the way ours is set up. We have a regular outlet that the engine block heater plugs into. During the winter months I will leave it plugged in and it's a good idea to 'plug-up' the other outlet with a child protector insert so that grease and grime stay out.
The outlet has a cover that I can close if nothing is plugged in.
MM.
