RV.Net Open Roads Forum: Toy Haulers: Will batteries charge when running on 120v?
Search only in Toy Haulers
 > Will batteries charge when running on 120v?
nmhuntr
Las Cruces, NM
Posted: 01/01/13 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
I believe the basic answer is no. I am thinking of adding a small battery charger to the TH that stay hooked up and charge automatically as soon as 110v is supplied via gen set or shore power. I am certain this has been tried and I am looking for some guidance. My initial thought is to get a small battery maintainer and wire it in. While at the house I keep the TH hooded to power and then when I boondock and run the gen set it will charge as well.
What am I missing?
Thanks
Greg
2005 Fleetwood Pioneer ASV 180FK
2008 Tundra
hmknightnc
Wilmington, NC
Posted: 01/01/13 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Your missing your converter. Your TH should have a converter installed that automatically charges your batteries anytime 110volt AC is applied. No need for a seperate battery charger. If your batteries are not charging when plugged in go find your converter and post the model number here, we can help troubleshoot
sch911
Rochester Hills, MI
Posted: 01/01/13 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. That's one of the things your converter is for!
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
RoyB
King George, VA
Posted: 01/01/13 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
You RV should have an on-board converter/charger unit to keep your batteries charged when plugged into shore power. Here is a simplified block diagram showing a typical 30AMP RV system...
It is important to have a modern technolgy converter/charger unit on the RV trailer as smart mode technology charging will not boil out your battery bank if left on for long period of times. I used to check once a week with the older converter/chargers unit and had to add battery fluids all the time. Now i still check on a regular basis but adding battery fluids is a thing of the past. The new smart-mode converter/charger unit take good care of your installed batteries...
Roy Ken
nmhuntr
Las Cruces, NM
So as long as I am hooked to any 110v sourse it will trickle charge or quick charge as required by it's own monitoring system?
I have a WF-8945AN-11 (in 2005 Fleetwood) and the book reads like that but I was skepticle to accept it as being all I needed.
sch911
Rochester Hills, MI
Posted: 01/01/13 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Why?
As long as you haven't made any modifications, then yes that's all you need....
hmknightnc
Wilmington, NC
Posted: 01/01/13 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, in theory. The WFCO converters (and I have one) are notoreous for not going into boost mode (quick charge in your terms) most caused by the trailer manufacturer using too long of wire runs and too thin wire between the converter and batteries.
Go check your TH battery voltage at the battery with a DVM when the trailer is plugged in. If you are seeing around 13.6volts then the WFCO converter is working
RoyB
King George, VA
Posted: 01/01/13 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
The older WFCO converters/chargers like the WF-8900 series are notorious for not going into smart mode charging when needed and alot of folks have changed them out for modern smart mode technology units like the PD4600 series or the IOTA series units. You only change out the converter/charger module and it will fit in the bottom compartment of the WFCO 8900 series power distribution panel where all of your 120VAC breakers and 12VDC fuses are located.
I have the same WFCO 8900 series power Distribution Panel in my trailer but use the PD9200 series convert/charger unit as it always goes into smart mode charging technology when needed. Change out is an easy process.... Contact Randy at BESTCONVERTERs for all the details you need.
Roy Ken
64thunderbolt
Az
Posted: 01/01/13 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Leaving the shore power plugged in all the time is putting undue milage on your conv. Flip the batt disconnect then switch the batt back on & plug it in 2 days before leaving to cool the fridge and top off the batt. Been doing this for years. I have had friends fry their conv here in this Az heat leaving them plugged in all the time. Not good.
Glen
04 Tail gator XT 34' 5th wheel garage model
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" turbo back exh sys
trucool trans cooler added
08 Arctic Cat Prowler 700XTX
Y-Guy
Tri-Cities, WA
Posted: 01/01/13 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
My converter/charger died this summer, when it did I upgraded to one with automatic 4-stage charging including boost, normal, storage and desulfation. So far been very happy with the results.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
