RV.Net Open Roads Forum: Tech Issues: Time to replace propane tank
 > Time to replace propane tank
red31
Bryan
Posted: 01/03/13 02:55pm Link  |  Print  |  Notify Moderator
Newer cylinders are $16 with exchange and you get 15lb of propane. What a deal!
martipr
Haltom City, Texas
Posted: 01/03/13 04:01pm Link  |  Print  |  Notify Moderator
Beware if you plan to use the Blue Rhino tank exchange service for buying propane. Blue Rhino is installing valves on their tanks that can only be refilled by Blue Rhino, meaning that you will be locked into their tank-for-tank service, and won't be able to get the tank refilled at your local propane dealer.
Blue Rhino is not only installing OPD valves, they are installing their OWN proprietary OPD valves, called Tri-Safe II valves. You can identify a TSII valve by the little triangular indentation on the side of the valve. In order to get flow IN to a TS2 valve, a magnetic key must be inserted into the indentation to hold a steel ball out of the way.
Per Blue Rhino: "Blue Rhino is the leader in the industry for providing the safest tanks on the market. Some, but not all of our tanks have a special safety device that prevents the refill by anyone other than a Blue Rhino specialist. They are called TS2 cylinders. The reason we designed them is simple. It's for the safety of our consumers!! We stand behind our product. We know how our cylinders are filled and that the highest level of accuracy and safety checks are performed. When our consumers take our cylinders and have them filled elsewhere, we cannot be liable or guarantee the safety of that cylinder. If your tank is not properly filled, damage to your valve can result, which can prevent it from performing properly.
Our business is propane cylinder exchange. We recommend that our customers only exchange because of the safety/liability issues associated with someone else filling our tanks. However, you, as a consumer, are free to fill your cylinder if you wish. Not all of our tanks offer the special safety feature. The way to identify the special TS2 valve tanks that cannot be filled is easy. If your tank valve has a small triangular indention on the side, then it is "tamper" protected. If you prefer to have a tank that can be filled by anyone, take that tank back to any Blue Rhino retailer and exchange it for one that does not have the triangular indention.”
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
diveman52
Collegeville,ca
Posted: 01/03/13 05:00pm Link  |  Print  |  Notify Moderator
lawaco12 wrote:
i was told by tsc that 10 yrs was limit they can be recertified but that costs $40 so im trying some place to exhchange cylinders have not found a place that has 30# cylinders that exchange
Porblem is you went to Tractor Supply and not a real Propane suppler.
40+ Years in Electrical construction.
Retired IBEW Local 595
Every Days Saturday
2008 Newmar Dutch Star 4035
mobeewan
Hampton, Va
Posted: 01/03/13 11:18pm Link  |  Print  |  Notify Moderator
I just had 2 - 20 lb cylinders and 1 - 6 lb cylinder recertified for the exorbitant fee of $5 each at Phillips Energy (a propane distributer) in Gloucester County, Va. Each one good for another 5 years. Next time I go north across the York river I'll get 2 more 20 lb cylinders recertified.
hotpepperkid
Kingman AZ
Posted: 01/04/13 11:10am Link  |  Print  |  Notify Moderator
Replace the valves
2000 Ford F-350 SRW 4X4 PSD Jayco Super Lite 29.5RKS (31') 5th wheel 50 gal X-ferflow in the bed tank. Banks big exhaust and Stinger kit.
HappyKayakers
Malabar FL
Posted: 01/04/13 01:14pm Link  |  Print  |  Notify Moderator
hotpepperkid wrote:
Replace the valves
Not good enough. The cylinder also needs to be stamped with a new date.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/
lawaco12
gallatin tn
Posted: 01/04/13 03:08pm Link  |  Print  |  Notify Moderator
The real propane supply is the one that wanted $40 to recertify. Plus they charge per tank $29. tsc charges by gallon $4+change both are ameragas
C Schomer
Pueblo West, Co.
Posted: 01/04/13 06:24pm Link  |  Print  |  Notify Moderator
Hmmm! I inspect and refill my own. Craig
RAS43
Littleton,CO
Posted: 01/04/13 06:55pm Link  |  Print  |  Notify Moderator
I have exchanged quite a few tanks with Blue Rhinos just to get newer tanks and then had them filled elsewhere without any issues. Maybe Blue Rhino just wants people to come back so they come up with this message. [emoticon]
martipr
Haltom City, Texas
Posted: 01/05/13 02:12pm Link  |  Print  |  Notify Moderator
My post includes a quote from a Blue Rhino letter which clearly states that they use two different valves. The valve with a small triangle in it is a proprietary valve and can only be filled by Blue Rhino. If the valve doesn't have the triangle it can be filled anywhere. This quote from Blue Rhino states that any Blue Rhino dealer will exchange a non-refillable for a refillable tank.
The point I was trying to make is that if you want a tank that can be refilled anywhere make sure it does not have the triangle.
