RV.Net Open Roads Forum: Fifth-Wheels: What should roof look like
 > What should roof look like
h2ojocky
orange county
Posted: 01/03/13 03:19pm Link  |  Print  |  Notify Moderator
I am shopping for a used 5th wheel and during an inspection of the roof I noticed a section of the rubber roof appeared to not be glued down. I could push it down slightly. Should the entire rubber roof be adhered to the roof decking? Is this a problem? The trailer is a 2004 Montana.
How old of a trailer is too old to purchase?
Thanks for your assistance.
Russ
ScottG
Bothell Wa.
Posted: 01/03/13 03:24pm Link  |  Print  |  Notify Moderator
Yes, thats a problem but sadly a fairly common one. The wind speeding over the top of it will cause lift and the membrane will continue to billow more and more. I would avoid a trailer with this problem since you'll eventually be looking at a new roof.
Scott, Grace and Wesly
2018 Silver Fox 32A - many mods to come!
H0NDA eu2000i
tvman44
Southwest Louisiana
Posted: 01/03/13 03:25pm Link  |  Print  |  Notify Moderator
Should be all glued down but unfortunately spots not adhering to the decking is not uncommon.
Papa Bob
Husky 16K hitch, Tekonsha P3,
joegray
British Columbia, Canada
Posted: 01/03/13 03:30pm Link  |  Print  |  Notify Moderator
My 5th has some areas as well that are not as tight as the rest. It
's a barganing item, I think a new roof is around $4000. If the rest of the unit is really good,it might be worth to give a lower offer and then replace the roof only if it really needs to be done. It will probably last for years the way it is. JMHO
Slownsy
Posted: 01/03/13 03:50pm Link  |  Print  |  Notify Moderator
It coud be reglued patched etc
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
Dave H M
IL
Posted: 01/03/13 04:06pm Link  |  Print  |  Notify Moderator
I think more clues on the type and size of the area is in order.
jimmyfred
Tx
Posted: 01/03/13 04:14pm Link  |  Print  |  Notify Moderator
........When cold my roof will show the divisions between the plywood , when hot , come summer , they disappear ! See if you can take insurance coverage that will cover a major % of any damage that might occur ., jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
Goostoff
Wisconsin
Posted: 01/03/13 09:33pm Link  |  Print  |  Notify Moderator
My roof is doing the same thing on my 05 Cedar Creek. I went to the dealer and they told me not to worry about it that it was normal and wouldnt be a problem for a long time.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
sem1
selkirk
Posted: 01/03/13 09:49pm Link  |  Print  |  Notify Moderator
Run
goshe
Denver
Posted: 01/04/13 08:19am Link  |  Print  |  Notify Moderator
My book says "Because of the manufacturing process, air pockets and/or visible spots may be seen in the rubber roof. These visible spots can be caused by debris (wood, staples, screws, etc.) that are between the rubber roof and decking or by imperfections occurring during the rubber roof manufacturing. In most cases, these are considered cosmetic in nature and seldom require any corrective action."
For what that's worth
2007 Duramax, 2009 Hallmark Guanella, 2013 Cougar 28SGS
