RV.Net Open Roads Forum: Waste Water Totes Seem To Be A Waste
 > Waste Water Totes Seem To Be A Waste
Page of 5
RVUSA
Orlando, FL, USA
Posted: 01/05/13 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
LynnandCarol wrote:
Friction and heat from pulling that plastic tank is bad bad bad. We bought a macerator and pump that waste into the tank sitting in the bed of the truck. We can then take it where ever we need to go without worrying about going 5 miles and hour. Since you are emptying from higher up it seems to go better also. We stay in federal and state parks most of the time and they do not have sewer so we use ours a lot of the time. Had the same blue boy for years.
Finally, a reason for buying the macerator that I did 4 years ago. Thanks!
Wherever I happen to park
Posted: 01/05/13 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I had a barker Blue tote (10 gallon) i used for many years when I had a trailr.. Not only that I "Abused" it, the 10 gallon size is not designed to be towed but I modified a hitch fork (yes, that is proper. Hitch Fork) for a 15 gallon tote to work on it (Details on request) so i could tow it cause 10 gallons plus tote is .. Well, heavy
I could really use one in the 38-42 gallon size. In a few months (Well actually next fall)
lizzie
Unaka (near Murphy), NC
Posted: 01/05/13 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
We bought our first one today at CW. It is a 15 gallon Tote-N-Store. In all our years of camping we have never needed one but we stay in this particular state park for two weeks at a time and need to dump our grey water. We are thinking of donating it to the park. The little wheels on it don't look very sturdy but it did a good job. lizzie
shum02
Burlington ON CDA
Posted: 01/05/13 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I've had one Tote-N-Store for 7 years and another for half that. I also use my Flojet to pump the waste into the totes while they are in the back of the truck and transport them that way. No leaks so far, totes I have are very sturdy.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 01/05/13 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 32 gallon Barker tote with the side valve for over 10 years now. Last summer I replaced all the wheels because the rubber finally disintegrated. (not bad for probably hundreds off miles being towed over 9 years). Other than the rubber on the tires, the tote is still is great shape. I do keep loosing the little cap where the garden hose screws on, but I finally bought a few plastic ones from Lowes so when I forget to put them on and lay them down and then leave, I can replace them
I don't understand why you're having such bad luck with yours. I do take special care of mine. It's washed out well after every trip, rinsed after every use, drained in the winter, and stored in our shed completely out of the elements in the winter. In transport, it's in the back of the pick-up bed under the shell, and when towing it with the truck I never get over 5-10 mph, watch for bad cracks and holes in the road and do my best to avoid hitting them. It's never kept in the sun, always under shade and always drained.
I don't know how you're taking care of yours, but if you're just using it without giving it a little extra attention and protection and care and preventative maintenance, letting it be exposed to sunlight, excessive heat, or filled with fluid and frozen in the winter, that would explain why it's leaking.
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
jerem0621
Sequatchie, TN
Posted: 01/05/13 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2 wheel 25 gallon tote-n-store. Very robust unit.
I've never trusted the 4 wheel design. Something about the caster design just irks me.
The 25 gallon is smaller than my holding tanks but I can maneuver 25 gallons pretty easy. 1-2 trips is no big deal IMO.
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
wbwood
Mooresville/Troutman, NC area
Posted: 01/06/13 05:31am Link  |  Quote  |  Print  |  Notify Moderator
We have the thetford 35 gallon. Have had it several years now and no issues. It does stay in our garage when not in use. It gets used maybe a total of a week to two weeks a year. The only time In its in the sunlight is when it's in the back of the truck during travel. We don't take it if we are staying at.FHU site. If you use it heavily then a couple years is probably a decent timeframe. I guess it also depends on how you are pulling it to the dump station and how far. They are meant to go very slow, usually way slower than the speed limit in a park. Also if you are pulling over a gravel road, then that is likely going to cause more havoc on it.
Brian
RVing Illustrated
2010 Keystone Sprinter Select 31BH
2001 Coleman Santa Fe
wbwood
Which state park?
BrokenElbow
Valencia, CA
Posted: 01/06/13 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a 32 gal 4 wheel Barker. Changed all 4 wheels to air tires. Worked well, but then got a Flojet Mascerator and now do what others have mentioned. I put the tote in the back of the tv and pump up into it, drive to the dump and use a short slinky to empty it. I store it in the garage (out of the sun) when I'm not going to a site with full hook up. Works great for both grey and black.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
Ron3rd
Upland, CA USA
Posted: 01/06/13 07:27am Link  |  Quote  |  Print  |  Notify Moderator
...also as another member mentioned, you should contact Barker anyway, there's a good chance they will replace it even though out of warranty. Mfgs often want to see defective parts and get them back to identify a potential problem.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
Page of 5
