RV.Net Open Roads Forum: Tech Issues: Schumacher Converter Upgrade
 > Schumacher Converter Upgrade
otbiker
Kerrville TX
Posted: 01/08/13 03:49am Link  |  Quote  |  Print  |  Notify Moderator
We recently purchased a 2013 Winnebago ERA. Winne is now using a single stage, all-in-one converter from Schumacher. I ordered a 4 stage deck mount charger from Best Converter.
I have written a tutorial with pictures and Randy at Best Converter posted it to his website.
The bottom line of text is "clickable"
Schumacher Upgrade How-To
* This post was edited 01/08/13 04:16am by otbiker *
Marty & Martha in Kerrville
2013 Winnebago ERA
RoyB
King George, VA
Posted: 01/08/13 04:28am Link  |  Quote  |  Print  |  Notify Moderator
You all will be famous now....
Your batteries will love you for this...
mikebo
Maryland
Posted: 01/21/13 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Marty,
I just bought a 2013 Winnebago Access and am thinking about following your lead. Did you remove the Schumacher converter? Disconnect it from the 120 volt side. I wasn't sure from your article.
Thanks
Mike
2013 Winnebago Access 31wp
2010 CRV toad
mena661
Posted: 01/21/13 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, I cannot believe they're going back to single stage converters. Well, I guess if Winnie's doing this others are sure to follow.
Trojan L16 6V's 740 Amp-hours
otbiker
Kerrville TX
Posted: 01/24/13 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
mikebo, The Schumacher unit cannot be removed as the fuse panel / breakers / charger are all one unit. You simply disconnect the charging section of the Schumacher.
smkettner
Posted: 01/24/13 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
So if the Schumacher fails you are supposed to replace the entire distribution panel
Does Schumacher have a website with details? I could not find it.
675 watts solar
otbiker
Kerrville TX
Posted: 01/25/13 05:02am Link  |  Quote  |  Print  |  Notify Moderator
It appears this unit is being made for Winnebago. You're right, no info at Schumacher. There's a few of us out there that determined it was a single stage charger fixed at 13.9 volts.
HiTech
Posted: 01/25/13 05:20am Link  |  Quote  |  Print  |  Notify Moderator
Is there really a reason to disconnect it vs just putting in a switch into the AC input? Seems like it could be handy for this and that, as well as being a backup to the multi stage charger? How many amps is it? Is the output voltage manually adjustable?
Jim
smkettner
Posted: 01/25/13 08:48am Link  |  Quote  |  Print  |  Notify Moderator
13.9 fixed in the TX heat will be hard on these Winnebago batteries
mena661
Posted: 01/25/13 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Yep.
