daamac
If I'm in a really rural area, I plan out stops somewhat - like filling up in a town with fuel, even if I'm only half empty.
If I'm not in a rural area, I don't plan out stops - but I do start to look for fuel no later than when my gauge reads 1/4 tank and I carry 5 gallons of diesel in a jug.
Also, I try to avoid filling up in a large metro area as the pumps are often not friendly to large vehicles plus the traffic is often chaotic.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
Lantley
Ellicott City, Maryland
I have a diesel getting fuel finding gas is simply not an issue. Truck stops are plentiful and my fuel range is more than sufficient.
Getting fuel/ finding stations is really not an issue at all for me. One less thing to be concerned about.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
francheska
Canada
My TT is 36 ft with hitch so with truck around 50 ft. This last fall we went around 9,000 miles in 92 days.
My DW says the best thing I purchased was the Next Exit book. If you travel interstates its excellent.
Tells you what stations are there, what products offered (diesel-gas-dump-ect.) and what side of the interstate they are on. Also tells you if they are big rig friendly. Also much more information. So I check
gas gauge then ask her to check for exits in the next 50 miles or so that we might want to use. Its great
Good luck Bob
goducks10
Keizer OR
Never had a problem getting in and out of gas stations. Just need to look ahead for situations. I will scan the lot quickly and if theres no way out I keep going. I pull 31' OAL with a 169" WB CC LB truck. I've gone into gas stations before and had people block me but I just wait a bit and they will move.
mister_d
Southeast, MI - hardly qualified to be a
Aim for exits with multiple gas stations. Really any where you can pull in forwards, you should be able to back out of. Just be careful, take your time, and forget about what anyone thinks of you.
Our Adventures
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
Me '77 DW '78
DD '04 DS '07
the e-man
Virginia
Great question. Here is what I have learned. Don't use regular gas stations if you can avoid it. For the first two years, we just stopped wherever and found ourselves getting frustrated waiting for cars who didn't understand that we couldn't move easily, having to turn too tight for the hitch, backing the trailer in awkward places, etc.
Now, we have the Flying J app on the phone. We try to do everything in one stop; fuel, lunch, and change drivers. We have fewer stops and spend less time at those stops. Not sure if Flying J is the best and I am open to other opinions. But, it sure is set up well for a truck + camper and has made our travels go more smoothly.
Most places we go have fuel stops placed frequently enough. If we are traveling long distances in rural areas, like Montana, I bring an extra 5 gallons just in case.
djcjc
minooka
We pull 33 ft hitch to bumper and fuels stop not a problem truck stop are more convienient but regular stations work to not all islands have diesel so have made a couple laps sometimes to get pump we needed. Getting around is not as hard has you would think good set of mirrors and wide turns so far have never got in a place I could not get out of.
Javi1
Waco, TX
We travel a lot of secondary roads in Texas and adjoining states so I usually know where I'm at and how far to the next interstate crossing where I'm likely to find a fuel station I can pull through with my rig which is about 55 or so foot... Some small towns will have a major secondary road crossing and there will usually be a fuel station in the area if I miss an interstate... Fortunately my range when towing is about 400 miles so it ain't too bad.. most places we're there before we need fuel..
fla-gypsy
North Florida
I evaluate every fuel station before I pull off the road. If you get yourself into trouble one time it can be costly and difficult to recover. Think before you turn off of the road.
69 Avion
Phoenix, Arizona
I have had no issues with my 34' Avion. I have had it in some tight spots. The toughest part is when you are obviously waiting in line to fill up and some jerk pulls a car in front of you since he can get to the open space faster. I have seen that happen a couple of time, and not just to me. Be patient and cautious and everything will work out fine.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
