Sailingbum
shambala
Greetings,
I have aquire a 1993 RT 190 popular with a rear floor storage hatch. This compartment hangs lower then the frame enough to block the instaltion of a stock van tow hitch. Does anyone know of a tow hitch tha will fit. Curt makes a class 1 euro vesion that looks like a posible but there are no measuments and it is mailorder. Any wise to
tidits would be apprecated.
edited 01/10/13 08:53pm by Sailingbum *
1995brave
San Antonio, TX
Where in the world are you? Check the local U-Haul places, some carry hitches in stock.
1492
Washington, DC
Moved from Forum Technical Support
Sailingbum
shambala
My mistake Brave . I meant tow hitch. Not Bar. The Uhaul I went to wants $370 to install one and I would have to wait a week for it to come in. If you have any helpful infomation concerning my question without the sarcasm I would appreciate it.
1995brave
San Antonio, TX
Most auto Parts stores sell Class 1-5 receivers. I picked U-Haul because most here have them in stock. You can also check PEP Boys, AutoZone, NAPA, etc, but they will need to order it for you.
Sailingbum
shambala
I will try a different Uhaul dealer (one bad apple theorey). I was very supicious of this one who claimed they could not just sell the hitch but had to install it also ($350.( On a previous vist for another vehical they want $160 just for the wiring). I bought the whole Hitch kit online for $80 and installed it in a lazy 1/2 hour.
I have in the past purchased a stock Reese hitch from Walmart for a Dodge B350 van. It would have required removal or damage of the custom installed storage compartment previously mentioned.
This is not a stock B350 item but a custom application required for the 1993 RT 190 POPULAR Dodge RETROFIT upon the vehical which requires a drop mounted hitch cross bar approximately 2 1/2 inches lower then the stock hitch redily available.
IF YOU OR ANYONE HAS MADE THIS ADAPTION OR IS FAMILIAR WITH THE CURT CLASS 1 EURO HITCH for the B350 and if it will work on the RV adaption (Class 1 should be fine for me) without any customizing please extend your knowledge this way.
Thanks for your input.
Sailingbum
shambala
This reply from the Roadtek service dept. along with plans for a custom built hitch. I am going to purchase a Standard Reese hitch and alter the storage compartment. The extra 1/4 of a square foot that blocks a standard hitch was really ill concieved.
Notice***Good Morning,
An off the shelf hitch will not work.
You will need to get a custom hitch built.
Roadtrek Motorhomes Inc. used a custom built hitch and no longer carries stock of these.
You will need to have a custom fabricating shop or hitch supplier build a hitch for you.
It is advisable that you bring your unit and these instructions to a local fabricator.
This information should help with a local hitch builder to make you a customized hitch.
888 ROADTREK (888-762-3873
