Digging through your old posts it looks like you have a 2004Itasca Suncruiserr model G38G or R. Looked at the wiring diagrams for the automotive wiring and traced the 12awg yellow wire labeled L5 back to the fuse. The fuse also affects the battery boost switch and the radio power switch. The fuse is located under the dash pod, the 4 block fuse panel and is probably the first fuse on the block.
I think you need a new electricition, it took me longer to find the year and model of your RV than to trace the wire back, it was all on the same page.
Location: Automotive Wiring Diagram Sheet 1 of 5. Outlets B-1, fuse block D-4.
1995brave wrote: Digging through your old posts it looks like you have a 2004Itasca Suncruiserr model G38G or R. Looked at the wiring diagrams for the automotive wiring and traced the 12awg yellow wire labeled L5 back to the fuse. The fuse also affects the battery boost switch and the radio power switch. The fuse is located under the dash pod, the 4 block fuse panel and is probably the first fuse on the block.
I'll provide him with the wiring diagram - providing that I can get online when he gets here - and see what he says.
My problem is that I'm in the middle of nowhere and have very few choices - one - to take care of my problem. I just need him to get me home (1100 miles) so I can have it proerly taken care of.
You can also download all the documentsand save them as a pdf file on your computer, that's what i did for mine.
I also printed out a copy and put in my manual that i keep in the RV.
