RV.Net Open Roads Forum: Surge protector, Voltage regulator who comes first?
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Surge protector, Voltage regulator who comes first?
GULFSTREAMER37
WATERBURY
Posted: 01/19/13 07:52am Link  |  Quote  |  Print  |  Notify Moderator
For those of you who have both which one do you put closest to shore power.
I have the Progressive Industries 50 amp Hardwire Surge Protector EMS-HW50C already installed.
http://www.rvupgradestore.com/Progressive-Energy-Management-System-240Volt-50amp-p/emshw50c.htm
Wired in under the bed near the Transfer switch.
Just picked up the Surge Guard Voltage Regulator - 50 Amp
http://www.rvupgradestore.com/Surge-Guard-Volatge-Regulator-50-amp-p/55-2715.htm
And the Shoreline Reels Hand Crank 50 Amp Power Cord Reel
http://www.rvupgradestore.com/Hand-Crank-50-Amp-Power-Cord-Reel-p/cc50h01.htm
I plan to mount these in the compartment, but then I had a thought.
Does the Surge Guard Voltage Regulator Need Surge Protection?
Or is it able to handle surges and I only need to protect the Coach?
Ted.
2007 GULFSTREAM CRESCENDO 37 MODEL-378 FRED CUMMINS 5.9 300 HP ALLISON 2000MH 5 SPEED, BANKS DIESEL TUNER WITH IQ 2.0 SYSTEM FOR UP TO 85 RWHP AND 203 RWTQ GAINS.
ronfisherman
SE Michigan
Posted: 01/19/13 08:07am Link  |  Quote  |  Print  |  Notify Moderator
From TRC Web page.
Using the TRC Voltage Regulator in conjunction with a Surge Guard RV power protection product provides the ultimate combination of low voltage and surge protection. The Surge Guard must be plugged in after or down stream of the TRC Voltage Regulator.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad
Super C Group Forum
accsys
Green Cove Springs, FL
Posted: 01/19/13 08:19am Link  |  Quote  |  Print  |  Notify Moderator
I guess I fail to see the need for a voltage regulator if you have a EMS-HW50C?? [emoticon] The EMS-HW50C will only allow voltages in within the "good" range and nothing in an RV requires a tighter voltage variation.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
GULFSTREAMER37
WATERBURY
Posted: 01/19/13 08:24am Link  |  Quote  |  Print  |  Notify Moderator
Keeps things from shutting down during low voltage Summer Days.
I need My AC I am from the Northeast Polar Bear territory.
Ted.
JohnnyT
On The Road
Posted: 01/19/13 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I have my surgeguard wired after the transfer switch. So no power gets into the coach that is unprotected including the generator.
When I use the voltage regulator (Hughes autoformer in my case) It is between shore power and the transfer switch. Mine is not hard wired.
JohnnyT
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
GULFSTREAMER37
WATERBURY
Posted: 01/19/13 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I guess a better way to put it is, Is the voltage Regulator susceptible to Power Surge Damage?
This thing cost over 600 and don't want to blow it up in the event of a Power surge or Lightning Strike.
Ted.
time2roll
Posted: 01/19/13 10:23am Link  |  Quote  |  Print  |  Notify Moderator
The booster will do no good if the PI EMS turns off power. You could also leave the booster out of the circuit unless needed for low voltage. During an electric storm consider unplugging everything. Or if you really want to go crazy get a low cost surge protector(no voltage protection) to go first, then booster, then PI EMS, and finally the RV.
675w Solar pictures back up
M GO BLUE
Southgate, MI
Posted: 01/19/13 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Ted.
But that is what you want your surge protector to do...shut down your entire system because of low voltage to protect your appliances, etc....
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
GULFSTREAMER37
WATERBURY
Posted: 01/21/13 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Ted.
That is only 1 feature of the Surge protector.
Which I don't need to worry about with a voltage regulator :-)
CT_WANDERER
E. Lyme, CT
Posted: 01/21/13 08:49am Link  |  Quote  |  Print  |  Notify Moderator
You can not have it both ways. You either go with the power booster and hope you don't get a spike to kill it, then have the PI unit to protect the RV. Or you go with the PI which will shut down you RV power if there is a power condition problem. And if you have the booster after the PI, it will not do you any good because the PI will drop you out if the voltage is low before the booster and push-it back up. I have the PI only and it is installed after my transfer swith. JMHO Gary
