squires5
Winthrop, ME
I put calls into two local reputable private rv repair shops to get estimate on roof work. I have a soft spot which has spread to almost a 4 by 4 area (started at about 2x2 area last year) so I need to bite the bullet and address it. Looking at around $3500 to replace the rubber roof and the plywood. Ouch-- I replaced the roof to the house for the same money!
Has anybody done just a half of the roof. The rest is solid with no signs of leaking.
1998 Coachmen Lepracaun 30MB
DH'70&DW'69
DS'96,DS'03,DD'04
Bordercollie
Garden Grove, CA, USA
Price seems reasonable considering skills, labor and materials. No competition for RV roof repair work, and work is not the same. Consider selling your rig and applying what you get for it to a newer rig with no leaks.
Gale Hawkins
Murray, KY
Have you found where the water is getting into the MH? If the leak can be stopped the soft spot may never be an issue based on our 8'x8' soft spot that we purchased in 2007 that was due to leaking radio antenna that was removed and the hole patched with Eternabond.
If it has doubled in size it is still leaking I expect.
Trading is a thought. The $3500 bill will not add any value to the MH but will make it easier to find a buyer.
squires5
Winthrop, ME
I purchased the rig last fall (Sept '11)-- I did get a good deal on it-- I can invest in the roof and still be behind blue book and less than what similar rigs are selling for. Selling and buying another won't necessary save $$. I knew this was coming- I guess I was hoping of different answers. I know the work is not the same as a house and appears to be much more labor intensive as well as technical.
squires5
Winthrop, ME
I think the origianl leak was the caulking around the tv antenna. The soft spot was originally isolated to that; I caulked around the antenna and spread the caulking over the area where it was soft.
It has spread though- doubling in size over the last year. So it must either still be leaking somewhere (?) or the rot is spreading.
GTO66
I was at the tampa rv show this past week,and there was this booth there with a display on spray on roof coatings.My first thought was this is just a thin coating similar to spray on bed liners.However the material was about 1/4" thick and real pliable.I picked up a card as I would consider this if I needed a roof.The web site is rvroof.com.
Gale Hawkins
Murray, KY
If you do not want to fix the leak and bought it that cheap and want a new roof I would just go end to end while I was at it.
How many miles have you put on the chassis since you got it? What will it cost to get it ready for a cross country trip? Has the frig cooling unit been replaced yet?
Just some questions to help determine if another $3500 will get the rest ready for the road after you do the roof.
squires5
Winthrop, ME
Doesn't need anything to be ready for a cross country trip. We are taking it to Florida this spring (3200 miles round trip). The chassis is in great shape with 110K; well maintained- 2 year old tires all around, new shocks, brakes, full tune up at 100K, A/C is cold. The fridge works great, as does everything else.
Gale Hawkins
Murray, KY
Yes it sounds like you did get a deal.
j-d
Sunny Florida USA
At what I've seen of today's prices, the quote you have is actually good, given of course the job is done properly.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
