RV.Net Open Roads Forum: Curtain Pattern for a Class C Ford
 > Curtain Pattern for a Class C Ford
SantaNSC
Salley, SC
Posted: 01/22/13 03:41pm Link  |  Print  |  Notify Moderator
We're the proud new owners of a used 2008 Holiday Rambler Augusta, a Class B+. Unfortunately there were no privacy curtains to place on the inside of the windshield. It has the little "Sticky" circles to hold one up but no curtain. I wondered if anyone out there may have a pattern for making the curtains or a source to buy pre-made at a reasonable price? I assume that curtains for about any Ford 450 chassis, class C or B+ would work. Any help would be appreciated.
mikebo
Maryland
Posted: 01/22/13 04:33pm Link  |  Print  |  Notify Moderator
We use our outside windshield cover 95% of the time, it keeps it cooler in the summer and warmer in cooler weather. I would recommend buying one rather then worrying about a curtain.
Mike
Mike
2010 CRV toad
rockhillmanor
On the Road
Posted: 01/22/13 05:06pm Link  |  Print  |  Notify Moderator
Ditto x2
Mine came with the curtains. Tried them once and that was it.
You can see 'right thru them' at night as my one friend pointed out!
I either put a van windshield sun shade in the window and pop up nylon side window covers....or if staying longer the outside windshield cover.
Just bought these with palm trees, what a stitch! [emoticon]
fyi: When buying the outside ADCO windshield cover make sure you buy the correct one that works with the type of side mirrors you have.
Here's a pix of what it looks like. Camping world carries them for about 50 bucks.
http://www.sunpromfg.net/Adco-Class-C-Vinyl-Windshield-Covers-p/adcoclassc.htm
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
wolvereeny
SE Michigan
Posted: 01/22/13 05:24pm Link  |  Print  |  Notify Moderator
I would also vote for the outside cover. It also helps reduce heat in the summer by reducing sun coming through the windshield
Gene in NE
Omaha
Posted: 01/22/13 09:15pm Link  |  Print  |  Notify Moderator
There is a negative to having the windshield cover on the outside. A real pain in the rear to do if windy or in a monsoon rain. Also, what do you do with the curtain when you are ready to go and it is soaking wet?
Our R-Vision Trail-Lite is very similar to your Holiday Rambler. Monocco bought R-Vision and then used the construction technique and floor plan of the Trail-Lite and had Holiday build a couple of the floor plans. The reason I mentioned that is that our ceiling is carpeted and my wife found some lightweight (parachute type) material and merely cut to shape, sewed the positive side of velcro in spots about 6" apart. We then stick the sheet to the ceiling.
Here is one (a little pricey, but nice) to consider Easy Living Industries.
2002 Trail-Lite Model 211-S w/5.7 Chevy (click View Profile)
Gene
Handbasket
Asheville, NC
Posted: 01/23/13 05:55am Link  |  Print  |  Notify Moderator
One more disadvantage of an outside cover... It negates the "bed to driver's seat" niftyness of a Class C. You can't just drive off from potential trouble when boondocking, or as mentioned, in bad weather. You're required to go outside to remove it.
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
shamu32
WNY
Posted: 01/23/13 10:59am Link  |  Print  |  Notify Moderator
I have a 1997 E350 Class C. I bought two fold up windshield screens. One I use for the windshield. I made a cardboard template for the side window. I then traced it on the second screen, cut it out and had my wife sew around the outside edge with her sewing machine. Then I traced it on some leftover white poster board that was from a school project. I put the white poster board in the window first and then the silver screen, both are held in place by friction. Almost nine years of use and they are both good to go.
rockhillmanor
On the Road
Posted: 01/23/13 12:34pm Link  |  Print  |  Notify Moderator
Very clever! I use the sun screen for the windshield also. I like your idea of cutting up one for the sides. Thanks for sharing! [emoticon]
SantaNSC
Salley, SC
Posted: 01/23/13 05:27pm Link  |  Print  |  Notify Moderator
Great ideas !!!! Thanks Everyone!!!!
rvten
Crossville,TN
Posted: 01/23/13 06:40pm Link  |  Print  |  Notify Moderator
Our C has curtain behind driver/passenger seat.
We put reflective shield on inside of front window on hot days.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
