mwebber78
New England
SuwanneeDave wrote: In general, aluminum siding is found on lower quality units, called "stick and tin" construction in the industry.
I hope you meant "lower price" not "lower quality" for stick & tin towables. The outside siding has nothing to do with the actual quality of the unit you select. There are plenty of POS fiberglassed and Filon towables out there. In fact, in the most expensive of 5th wheels the framing is wood - wood is a durable building material and has a much better R-value then alum. framing.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
6.7 tow rig
kentucky
Having owned both I can honestly say I will never own another aluminum sided trailer. They are harder to take care of and I dont think they ever look as clean. My parents trailer has now been hit twice with pieces of rubber that have flown up off the interstate and they have two nice dents to show for it. Mine got hit by a baseball and luckily had no damage. I can also wax my whole TT in an afternoon opposed to the whole day and a half event my other trailer required.
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
jmtandem
western nevada
Quote: Having owned both I can honestly say I will never own another aluminum sided trailer. They are harder to take care of and I dont think they ever look as clean. My parents trailer has now been hit twice with pieces of rubber that have flown up off the interstate and they have two nice dents to show for it. Mine got hit by a baseball and luckily had no damage. I can also wax my whole TT in an afternoon opposed to the whole day and a half event my other trailer required.
Salt, like that used by Dept. of Transportations for winter highways, is corrosive to aluminum. Another thing I would think about for an aluminum trailer.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
LVJJJ
NW WASHINGTON
had both, much prefer aluminum, lighter, easier to take care of, no worries about delam. Got an 85 Wilderness, still shiney after all these years. I think gelcoat looks dirtier quicker than alum. (Funny how we all look at things so differently, we're probably not helping the OP at all).
1965 CHEVY VAN, 292 "Big Block 6"
1985 WILDERNESS 3000CL
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
nitrohorse
pa
jmtandem wrote: Quote: Having owned both I can honestly say I will never own another aluminum sided trailer. They are harder to take care of and I dont think they ever look as clean. My parents trailer has now been hit twice with pieces of rubber that have flown up off the interstate and they have two nice dents to show for it. Mine got hit by a baseball and luckily had no damage. I can also wax my whole TT in an afternoon opposed to the whole day and a half event my other trailer required.
Excellent point, since many of us consistently tow our aluminum skinned tts on snow covered interstates. Just curious, how does salt affect a steel frame, cross members, or axles? Really makes you wonder how Airstream stayed in business this long....
nitrohorse
pa
In reality, it's personal preference. I prefer aluminum. There's pros and cons to each, pick your poison...
jmtandem
western nevada
Quote: Excellent point, since many of us consistently tow our aluminum skinned tts on snow covered interstates. Just curious, how does salt affect a steel frame, cross members, or axles? Really makes you wonder how Airstream stayed in business this long....
Nitro,
Salt is bad for steel as well. However this comparison on this thread is between siding that was aluminum or gelcoat. Both would presumably have steel axles and frames since almost all trailers do not use aluminum frames.
As far as Airstream staying in business all these 80 years with 75 percent of all Airstreams still on the road, I guess they make a timeless coach, no rubber roof, no delam on the sides, excellent towing characteristics, iconic trailers that many associate with the ultimate in a towed trailer and for some it is the pinnacle of RV ownership. Sort of like the Harley Davidson fraternity following. Either a person rides Harley or they ride brand X. With Airstream it is an Airstream or a 'standard box trailer'. Very similar.
After a tow on a road with winter salt, wash it off with a hose underneath the coach. That should address the salt issue for those that tow in winter. Not really a big deal. We do that all the time in our area especially when crossing the Sierras in winter.
mwebber78
New England
I'll second the above poster, if I were worried about salt on the road I'd be done from October till May. Even in May, many roads still have a salt layer that doesn't wash clean until a long rainy week. A hose or power wash and diligence to touch up surface rust is good care in Maine or California
nitrohorse
pa
Jmtandem,
I would venture to guess that Airstream would have changed their construction material many years ago if corrosion was an issue. I think you wanted to make the OP aware of every possible adverse scenario involving an aluminum tt, but corrosion is really a non-factor with them.
edited 01/25/13 04:43am by nitrohorse *
jmtandem
western nevada
Thanks. Here corrosion can be a huge problem for cars, trucks and RV's if not washed off after each exposure. Salt is never used on runways since aircraft are aluminum. I think the Airstream issue may be due to protective coverings over the aluminum or something else similar to applied protection for aircraft frames. One other thing with aluminum and this can be/has been an Airstream issue from time to time is corrosion/cavitation from small electrical currents.
However, if the OP wants aluminum then go for it. There is also a downside to filon or gel and that has been already identified. I prefer gel over aluminum but if I wanted an Airstream I would get one regardless of the roof, siding, salt, or electrolosis.
