RV.Net Open Roads Forum: Class A Motorhomes: OOOP's Brush fell in black Tank
 > OOOP's Brush fell in black Tank
Page of 5
IBDTrader
Posted: 01/23/13 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I was cleaning toilet and the head of the brush fell in black tank and disappeared / What do I do now?
Dick_B
Palos Heights, IL USA
Posted: 01/23/13 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Is the brush head plastic or wood?
If wood you might trying to fill or partially fill the black tank to see if the brush might float to the top of the liquid to where you can hook it with a coat hanger or something else.
If plastic I have run out of ideas.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
IBDTrader
Posted: 01/23/13 07:35am Link  |  Quote  |  Print  |  Notify Moderator
It is plastic. If I hook up drain hose and open valve will it float out ?
rgatijnet1
Posted: 01/23/13 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Most toilets drop the waste onto a pipe where it makes a 90 degree turn before going into the black tank. The brush may just be right at the bottom and within easy reach, with a small hand, like a wife would have.
Naturally if the toilet has been flushed, the brush is probably in the black tank and you will have to hope that it is small enough to pass through the drain.
downtheroad
Pacific Northwest
Posted: 01/23/13 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Mask and snorkel.
Seriously.....This is not completely uncommon. I have read where people have rented a pipe inspection camera unit and been able to find and retrieve whatever fell in the tank....(toothbrush, tool, cleaning brush, silverware, etc.)
Good luck on your "fishing" adventure.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
GWK
Mt. Gilead, Ohio
Posted: 01/23/13 07:43am Link  |  Quote  |  Print  |  Notify Moderator
We had this happen once several years ago but it was the whole brush. I was able to retrieve it with a coat hanger. So, now I keep a 3 foot string tied to the toiloet brush.
2011 Sportscoach 390TS
Cummins ISB / Freightliner XCS
Gary W. Kincade
midnightsadie
ohio
Posted: 01/23/13 08:13am Link  |  Quote  |  Print  |  Notify Moderator
harbor freight has the camera not bad on price .have fun .things do happen and now you have a camp fire story.
pbitschura
SE MN
Posted: 01/23/13 08:32am Link  |  Quote  |  Print  |  Notify Moderator
Don't waste your money on a piece of******camera. Read the reviews. A flexible parts retriever can be bought at any auto parts store or on the cheap, a coat hanger should work. Good luck.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
BobR
Aurora, Illinois
Posted: 01/23/13 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Fill the tank with water and try to retrieve it. If unable to get it, see if it flushes out.
msmith1199
Central, CA
Posted: 01/23/13 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a job to pay somebody to do. Whatever happens, you do have to get it out. If it is too big to come out the drain then that's where it will head and clog up that drain. I don't know much about the internal plumbing, but it seems to me that if it was small enough to fall into the toilet and get through the toilet pipe and into the tank, that it should also be small enough to flush all the way through the system and out the drain.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
Page of 5
