RV.Net Open Roads Forum: Class A Motorhomes: OOOP's Brush fell in black Tank
 > OOOP's Brush fell in black Tank
Page of 5
ArchHoagland
Clovis, CA, USA
Posted: 01/23/13 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Good thread. I was cleaning our toilets last week and got to wondering what would happen if I dropped the toilet bowl scrubber brush down the hole.
I think I'm going to add a stick or something across the end of the handle so it won't go down the tubes.
IBDtrader...if nothing else at least you have helped me out so this won't happen to me.
Let us know how things come out................
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
fcooper
Richmond Hill, Georgia
Posted: 01/23/13 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
If you decide you need a camera to let you see inside the tank, (and can wait for shipping) one like this has worked well for me. You do have to have a laptop or computer you can move with a usb connection.
usb cable camera
I think I would try the treble hook idea first. Good luck.
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
howdy35
Athens, Texas
Posted: 01/23/13 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
May be more trouble than it is worth but you might remove the toilet itself snd go fishing from there. I think you might have a better view for the brush. Someone who has removed their toilet could say if that would give you a better look for the brush.
I think the fishhook and the grabber from auto parts store would also be worth a try. All of us are going to be interested in how you finally solve this problem so I hope you will post the solution when the problem is solved.
1999 National Tradewinds
2001 Honda Odyssey--Toad
Fulltime Wanabee
RayChez
Barstow, Ca. USA
Posted: 01/23/13 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
I would fill the tank and then dump it. It does have a four inch outlet, so maybe it will just flow out. Worth a try!
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
2gypsies
Enjoying the West!
Posted: 01/23/13 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
There's usually a hole in the top of the handle to hang. I have tied a heavy string through that hole and slip it over my hand while holding the brush....just another precaution. Good luck in the meantime!!
Grandkids were visiting and the toilet got clogged. We called in Roto-Rooter. Worked in a couple minutes. Never did find out what fell down there. I don't think this would work for a brush though. Not kid related but when we're boondocking I often dump our dishpan water in the toilet so we have more grey water space. I saw the fork just as it dropped down the black hole. That was two years ago and haven't had any problems - yet. I assumed the fork passed through o.k.
* This post was edited 01/23/13 09:35pm by 2gypsies *
Extremely Happy Full-Timers for 16 years
.... now trying to adjust to 3-season traveling - and it isn't easy!
2004 40' Newmar Dutch Star Diesel Pusher
2004 Jeep Liberty
2gypsies
Enjoying the West!
Posted: 01/23/13 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Double Post.
sowego
northwestern corner of the Nebraska panhandle
Posted: 01/24/13 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Our pipe going down to the tank is not straight, nor is the pipe going out so if it's toilet brush with handle...odds are it may get caught somewhere going down or coming out. It is worth trying to snag it with a long piece of wire from either end. If it got all the way to the tank...if it were ours...well it might just be the resident tank cleaning brush. Let us know how it all comes out...if it does!
2002 Tiffin Phaeton
2005 Malibu Maxx toad
beave
Georgetown Texas
Posted: 01/24/13 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Get a new brush, their not much use after a dip in the black tank.
IBDTrader
Posted: 01/24/13 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Final out come....
* This post was edited 01/24/13 07:37pm by IBDTrader *
IBDTrader
Posted: 01/24/13 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Final out come.... Filled both tanks several times and drained them at the same time. No brush. Decided to run a long stick thru sewer hose and the little sucker was there. Thanks for all the comments. The one advice I will take is to get a rope and tie it on new one piece brush.
That could have been an expensive screw up. One estimate was $800 to pull tank if needed. So my advice to all tie a rope to a ONE PIECE brush.
Thanks For all the comments.
Page of 5
