RV.Net Open Roads Forum: Tech Issues: Near Miss Propane Freak Accident
 > Near Miss Propane Freak Accident
phillyg
Front Royal, VA
Posted: 01/23/13 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Well, good comments by all, and yes, I shut off the gas today when traveling.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
PatrickA51
Lost
Posted: 01/23/13 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
rrupert wrote:
That is one good reason why you should have your gas tanks shut off while traveling.
Maybe that is why I turn off the Propane when we are traveling between locations and then turn it back on only when we want to use it!
Popsie
Livingston, TX, USA
Posted: 01/23/13 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Times may have changed, but decades ago when I was a firefighter, kitchen stove fires were our most common call - fires from smoking were the most deadly. Of course, YMMV
HiTech
Posted: 01/23/13 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Trailers REALLY bounce around, especially those with no shocks or struts. Record a video back there some time and play it back. It takes a lot of securing of all loads to hold them well in place with all that motion.
Jim
* This post was edited 01/23/13 10:36pm by HiTech *
msiminoff
Silicon Valley, CA
Posted: 01/23/13 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto!
My propane tank valves are always OFF while I'm driving.
The fridge runs just fine on AC from the inverter and my alternator easily keeps up with the demand.
-Mark
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 01/24/13 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
First of all permit me to write, Thank goodness nothing bad happened!
I'm a big chicken, I close off the gas, and open the switch to the batteries when on the road.
rrupert
NW PA
Posted: 01/24/13 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
If you are towing a trailer I hope you have the emergency breakaway switch hooked to the battery.
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
2oldman
Winchester WA
Posted: 01/24/13 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Terryallan wrote:
It's rare, as you have to push and turn at the same time. .
Yah.. that is rare.
What happens to me is if I ever do turn off the gas (which I almost never do) I'll forget that the oven pilot is on.
Probably way more important to store things properly than turn off the gas.
SolidAxleDurango
OK, USA
Posted: 01/24/13 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
that wine bottle sounds more acrobatic than JFKs magic bullet.
TV = 07 Dodge Ram 3500 Dually 6.7 / QC-LB / CTD / G56 / 3.73 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 )
joebedford
Jasper, Ontario
Posted: 01/24/13 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
For years I wouldn't travel with the propane on but have been doing it for the last three years. I like the fridge to be cold when I arrive at my destination (no it WON'T stay cold after a long days travel).
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
