ROADSTARJR
NC
I'm looking at going full time and want to get a heated water hose, would like to know the best?
Joe
2004 Dodge 3500 DRW
2001 Sunnybrook 33 RKFS
old guy
Oregon (pronounced Or e gun)
buy only the length you need. they are very expensive
ROADSTARJR
NC
Thanks' But Who has the best ones?
WoodGlue
Los Angeles / Montana
I think there are only 2 mfgs making them. If I recall correctly, Amazon carries one brand and Camping World carries the other Brand.
WoodGlue
2002 Land Rover Discovery II
2013 LANCE 1685 Travel Trailer - Video Tour - Video Tour 2
Lance Uses Azdel - Why It's Better Than Wood In Your RV Walls
There Are 84 Less Chances Of A Roof Leak In A Lance
Lance Factory Tour
2014 LANCE 1685 On Order! Yay!
smkettner
Put "heated water hose" into amazon
675 watts solar
pianotuna
Regina, SK, Canada
Hi,
Probably better to run on tank water. The hoses are expensive.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
topjimmy
Olympia
If you are going Fulltime like I have the past 3 years you gotta have a heated hose or you can do like i do and go the cheaper route and get heat TAPE at the hardware store I think it cost me about 25 bucks and i also put foam tube wrapped around the hose also WORKS PERFECT and i have never had a frozen hose.I do not like traveling around with a full tank of fresh water it is just too much weight but that is a option to run just off the inboard tank when it gets cold
kelly94942
Beaverton, Oregon
Yup, that's what we did when we full timed, heat tape from the hardware store, wrapped with foam tube. Never froze!
Me and wonderful DH
Previous #1: 2007 Pacific Coachworks Tango 299BHS, 2007 Chevy Tahoe
Previous #2: 2010 Carriage Carri-Lite 36MAX1, 2008 Ford F-450 (full timed for two years)
Current: 2013 Dutchman Kodiak 300BHSL, 2004 Ford Excursion
PyrateSilly
Home
Here are some of the heated water hoses:
http://www.pirithose.com/index.php
http://heatedwaterhose.com/
http://www.rittenhouse.ca/asp/Product.asp?PG=2392&gclid=COqOwoOkgLUCFbKiPAodXhkAtA
http://www.nofreezewaterhose.com/?gclid=CPWgiZ6kgLUCFSOnPAodIz8Aww
Or you could go with the Heat Tape:
http://www.grainger.com/Grainger/ecatalog/N-1z0csvm
http://fluidxequipment.com/subcategory.cfm?id=36
http://www.lowes.com/pd_24490-72436-ADKS-500_0__
And here's how to install it:
http://www.foremost.com/mygreathome/?v=a&an=how-to-install-heat-tape
http://www.ehow.com/how_2002635_install-heat-tape.html
Hope this helps you.
Thom, Gascap and Christine having fun in a 1993 Monaco Crown Royale 40ft 300hp RV.
Our blogged repairs and travels
Golden_HVAC
Fulltime, CA, USA
So you really want a $250 heated water hose?
I would rather just fill up my fresh water tank on warmer days, and dump at the same time.
Fred.
