RV.Net Open Roads Forum: General RVing Issues: Heated Water Hose
 > Heated Water Hose
ROADSTARJR
NC
Posted: 01/23/13 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at going full time and want to get a heated water hose, would like to know the best?
Joe
2004 Dodge 3500 DRW
2001 Sunnybrook 33 RKFS
old guy
Oregon (pronounced Or e gun)
Posted: 01/23/13 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
buy only the length you need. they are very expensive
ROADSTARJR
NC
Posted: 01/23/13 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks' But Who has the best ones?
WoodGlue
Los Angeles / Montana
Posted: 01/23/13 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
I think there are only 2 mfgs making them. If I recall correctly, Amazon carries one brand and Camping World carries the other Brand.
WoodGlue
2002 Land Rover Discovery II
2013 LANCE 1685 Travel Trailer - Video Tour - Video Tour 2
Lance Uses Azdel - Why It's Better Than Wood In Your RV Walls
There Are 84 Less Chances Of A Roof Leak In A Lance
Lance Factory Tour
2014 LANCE 1685 On Order! Yay!
smkettner
Posted: 01/23/13 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Put "heated water hose" into amazon
675 watts solar
pianotuna
Regina, SK, Canada
Posted: 01/23/13 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Probably better to run on tank water. The hoses are expensive.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
topjimmy
Olympia
Posted: 01/23/13 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going Fulltime like I have the past 3 years you gotta have a heated hose or you can do like i do and go the cheaper route and get heat TAPE at the hardware store I think it cost me about 25 bucks and i also put foam tube wrapped around the hose also WORKS PERFECT and i have never had a frozen hose.I do not like traveling around with a full tank of fresh water it is just too much weight but that is a option to run just off the inboard tank when it gets cold
kelly94942
Beaverton, Oregon
Posted: 01/23/13 10:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, that's what we did when we full timed, heat tape from the hardware store, wrapped with foam tube. Never froze!
Me and wonderful DH
Previous #1: 2007 Pacific Coachworks Tango 299BHS, 2007 Chevy Tahoe
Previous #2: 2010 Carriage Carri-Lite 36MAX1, 2008 Ford F-450 (full timed for two years)
Current: 2013 Dutchman Kodiak 300BHSL, 2004 Ford Excursion
PyrateSilly
Home
Posted: 01/23/13 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Here are some of the heated water hoses:
http://www.pirithose.com/index.php
http://heatedwaterhose.com/
http://www.rittenhouse.ca/asp/Product.asp?PG=2392&gclid=COqOwoOkgLUCFbKiPAodXhkAtA
http://www.nofreezewaterhose.com/?gclid=CPWgiZ6kgLUCFSOnPAodIz8Aww
Or you could go with the Heat Tape:
http://www.grainger.com/Grainger/ecatalog/N-1z0csvm
http://fluidxequipment.com/subcategory.cfm?id=36
http://www.lowes.com/pd_24490-72436-ADKS-500_0__
And here's how to install it:
http://www.foremost.com/mygreathome/?v=a&an=how-to-install-heat-tape
http://www.ehow.com/how_2002635_install-heat-tape.html
Hope this helps you.
Thom, Gascap and Christine having fun in a 1993 Monaco Crown Royale 40ft 300hp RV.
Our blogged repairs and travels
Golden_HVAC
Fulltime, CA, USA
Posted: 01/24/13 12:01am Link  |  Quote  |  Print  |  Notify Moderator
So you really want a $250 heated water hose?
I would rather just fill up my fresh water tank on warmer days, and dump at the same time.
Fred.
 > Heated Water Hose
