edatlanta
Panama City Beach, FL
I fill up my fresh water tank and unhook the water hose when it will be below freezing and operate off of the tank. You can refill your tank even when below freezing if you allowed your host to drain after you unhooked it. Even with a heated hose, which I won't buy, you still have to worry about the water faucet you hook to. Not worth it for me.
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Mfar1234
PIRIT --- $100 - $200
AMAZON
Mfar1234
40' 2002 Alpine Coach, 400 ISL Cummings/3000 6sd Allison
2006 Dodge Ram 4x4
and Brodie,my dog
Trlrboy
Rockwall, Texas
We do the same thing as Topjimmy... heat tape. We bought a heat tape at Lowes that's 10' longer than the hose so that we could wrap one end around the connections on the trailer and then also around the spigot and pipe at the campsite. Works great.
2010 Montana 3400RL
Chevy 2500HD Duramax
PHOTOLINK
PyrateSilly
Home
We got our Pirit hose from Camping World on sale for about $50 during the summer when we did not need it. Seemed to be much cheaper then.
Thom, Gascap and Christine having fun in a 1993 Monaco Crown Royale 40ft 300hp RV.
Our blogged repairs and travels
doxiemom11
Alabama
We also got heat tape pipe insulation from the hardware. Never frozen yet and we leave our water hooked up. Lowest temp we have had was about 20.
CardinalCamper
Canon City Colorado
We fulltime in Kansas on our 2nd winter.Hose,Heat Tape,Foam and pipe wrap.Wrap the heat tape on faucet pipe and pipe wrap. Do Hose the same
We have been down to 6 degrees this winter and have not froze.
Charles & Dawn
2005 Cardinal 35 CKT LX
2000 F-250 PSD 7.3 4x4 Hypertech Power Programmer III, Firestone Ride-Rite Airbags, Air Safe 25K Hitch,Yamaha 125cc Vino Scooter.
Mike and Pat
Virginia Beach, VA
I got the Pirit hose as a gift last year and finally had a chance to use it this past week. It didn't work worth a toot. I am going back to the old school heat tape and pipe insulation like I have been using for the past 6 years. Never had a frozen pipe with the heat tape.
Mike and Pat
"Full Timing. But still working. At least for awhile.
Mike (Driver) and Pat (Navigator)
2004 Itasca Meridian 39K 330 cat
2009 Saturn Outlook toad
SMI Stay in Play Duo
Socrates,Kiira and Tiberius (Tonkinese Cats)
Maximus (Mini schnauzer)
sowego
northwestern corner of the Nebraska panhandle
Besides considering a heated water hose, also consider the faucet at the campground needs to be wrapped with heat tape &/or insulated or,under pressure in extreme cold it will freeze and even though you may have a heated water hose--you may have no water.
2002 Tiffin Phaeton
2005 Malibu Maxx toad
Carolina Cruiser
East TN
Use the heat tape method with foam insulation. We have a 25 foot hose and a 30ft tape. The extra tape on one end is left out in the compartment the hook ups are in and the end with the thermostat is wrapped around the spigot. The campground we are at now has both frost free and pvc piped spigots. Ours is PVC so we covered it with a trash can. We have had no issues and had temps in the teens several times. If you read the reviews on the heated hoses, and then add the price of the hose, save yourself some money. When the weather warms, I change to another hose and take the foam off the hose with the heattape and store it with it still attached. Gives me the chance to inspect the tape.
Albert & Tamara, the dogs Casey & Cody, Living the simple life.
God never said Saved by Grace;kept by performance.
RoyB
King George, VA
Here is a GOOGLE IMAGES search results...
I looked for 'HEATED WATER HOSE' ... Click on the view that catches your eye and find the source...
HEATED WATER HOSE
Roy Ken
