HiTech
With luck I will get my two AGM group 27 marine batteries on the way to a conference this morning. Anything I should look for to decide not to buy them, such as terminal voltage below a certain level?
Jim
pianotuna
Regina, SK, Canada
Hi Jim,
Identical recent date codes would be good.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
MNtundraRet
Bloomington, MN
Best places will add acid to lead/acid batteries when sold and charge them before you pick them up. Take your multimeter, or use theirs, the check battery voltage.
I would ask if the batteries were done this way. If not, how long did they sit on the shelf, and how will charged. Put them on a charger for a low current charge to 100%soc. Check voltage for a number of days to confirm voltage stays at 12.7 volts.
As mentioned by Don in past posts, it is possible a number of use charge cycles mat be needed to reach the true 100%soc capacity.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
pianotuna
Regina, SK, Canada
Hi Mark,
It is pretty hard to add acid to an AGM style battery? *grin*.
MNtundraRet
Bloomington, MN
Sorry! Missed that.
I have not had the second cup of coffee yet. Rest of post would hold true.
mena661
pianotuna wrote: Hi Jim,
Identical recent date codes would be good. X2
Trojan L16 6V's 740 Amp-hours
HiTech
Had a great talk with Mark at CBC Battery in Houston. I noticed some antique battery jars they had from my reading of the old school battery rebuild manual provided by a member here. Among other things they had a glass jar for a farm lighting battery from way back.
Mark gave me a $28 savings on the same two batteries in their email quote. Pays to read those old battery manuals LOL!
All the codes are the same except the cavity numbe on the injection molding for the case. I think the date code it ink jet printed on the end of the pre printed bar code label.
Now to get the mounting for them squared away on the trailer tongue.
Jim
BFL13
Victoria, BC
The real when made date code would be stamped on the plastic case somewhere. (with a letter for the month) (Trojan 6s have a date on the lead post) The sticker seen on top would be when last charged. The third sticker with the date punch outs is when you bought it.
Compare the when made date with the last charged date.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
mena661
I remember when I bought my batteries. Fun day. BFL, my date code was stamped on the case also.
HiTech
I will look when I get them out in sunlight. My eyes are not what they once were.
Jim
edited 01/24/13 07:31pm by HiTech *
