RV.Net Open Roads Forum: General RVing Issues: Heating Bed
 > Heating Bed
Page of 5
Deputy Chief P.O.
Linden, California
Posted: 01/24/13 09:52am Link  |  Print  |  Notify Moderator
We have both, but only use the heated mattress pad. It is wonderful.
My advice is worth what you paid for it!
Both of us are Retired Law Enforcement
2003 Pace Arrow 36B
Ansel Adams Edition
3 slide outs
FMCA
Good Sams Lifetime Member
2014 Jeep Patriot Toad
1rickw
Redwood City, CA USA
Posted: 01/24/13 09:55am Link  |  Print  |  Notify Moderator
Our son just bought us a heated mattress pad for Christmas for use here at home. I put it on very low just before going to bed and it is very comfortable. I would imagine that it would be much warmer if I cranked it up all the way, but set on a low number, it works great. It has an automatic shut off after 10 hours.
2004 Jamboree 26Q + great wife to travel with ">
2012 Honda Fit towing 4 down with BrakeBuddy
pianotuna
Regina, SK, Canada
Hi,
Heat rises. Mattress pad wins hands down. 12 volt is available but only in twin size so two would be needed. Draw is 7 amps per blanket. Lovely way to warm the bed!
Some mattress heaters may not run on msw inverters. It depends on the type of control they come equipped with. I suspect if it has auto shut off then msw inverters may let out the magic blue smoke.
I preferred to go 12 volt myself.
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
wborst
North Carolina
Posted: 01/24/13 10:11am Link  |  Print  |  Notify Moderator
We use a heated mattress pad (120V). Since heat rises, it makes the best use of the heat generated. Set it on 1 or 2 about 15 minutes before bedtime. Bed is nice and toasty when we climb in. [emoticon]
Brenda, Bill
Our little dog Madison has crossed the Rainbow Bridge
2003 Newmar Mountain Aire 40ft. Spartan chassis
400 hp Cummins ISL
Eycom
32043
Posted: 01/24/13 10:24am Link  |  Print  |  Notify Moderator
2oldman wrote:
Mattress heater. I'm assuming you're plugged in, cause if not you'll need a good psw inverter.
Agree. Winter travel with furnace t-stat set to 55°, the queen mattress in an extended cab-over of a TC can get pretty chilly in sub-zero temps. Memory foam topper becomes a concrete slab. A 10-15 minute warm-up with a mattress pad warmer makes everything soft and cozy for the night.
Quality 12v warmers are available at Electowarmth. They used to offer sizes in king, queen, double, etc. I purchased a queen size back in 04 from Backwoods Solar (same product/lower price) and it lasted 8 years. The pads were pinned to the mattress, not form fitted. Now, the manufacturer makes only one size, 36"x60". Based on experience, too many pins to deal with on larger mattresses, ie., tears in the middle of the mattress cover and possible overlapping of pad(s). Now, I use a 120v Sunbeam, form fitted, purchased at Wally World. You'll need a psw for off grid use. The controls are sensitive.
RVn Full-time
2oldman
Palm Springs
Posted: 01/24/13 10:39am Link  |  Print  |  Notify Moderator
The Texan wrote:
Sorry, but this is not correct info. We have a heated mattress pad and a MSW inverter has been its power source for years.
It is true if it's a newer pad with digital controls. And seeing how it's reasonable to assume he doesn't yet own one, it's likely that's what he'll get.
The Texan
Home ... Toquerville, UT .. Summer ... Cascade, ID
Posted: 01/24/13 10:46am Link  |  Print  |  Notify Moderator
I can buy one at any store today, that is "new" and will work fine with a MSW inverter. Over ½ of the ones built today have a analog control, many with a digital display.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
2oldman
Palm Springs
Posted: 01/24/13 10:48am Link  |  Print  |  Notify Moderator
Analog control with a digital display? How does that work?
M GO BLUE
Southgate, MI
Posted: 01/24/13 11:08am Link  |  Print  |  Notify Moderator
When you get to where you are going turn on the heat and take the blankets off the bed to expose the sheets to the heat...works for us
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
The Texan
Posted: 01/24/13 11:16am Link  |  Print  |  Notify Moderator
The control is analog, and the numbers shown on the control are digital. Has been done for years, not new technology. Ours is that way, with the LED numbers 1-5 for settings.
Page of 5
 > Heating Bed
