BillMFl
My 2012 38' Georgetown gasser is very quiet up to a little over 2000 rpm and 60mph. Slightly over 2000 rpm and between 60 and 65 rpm a rather loud howl seems to come not from the engine compartment but furthur back where the two exhaust pipes join the catalytic converter. Its totally rpm related because when I take my foot off the gass the noise completely stops even if my speed is way above 60. The noise actually slacks off a bit abouve 75. I'm guessing there might be some harmonic resonation going on above 2000 rpm. Anybody else experience this with the V10?. The engine performance is very good. Plenty of power and if I'm not using speed control I often catch myself creeping up to 75 or 80. At any speed the noise stops totally when I let off the throttle. So its not tire noise, etc.
Order is illusion. Chaos is reality. But right or wrong I'm still the captain.
Dale.Traveling
Newport News, VA
Check the heat shields on the converter and exhaust system in general. Had a Ford Ranger many years ago that did the same thing, howled at certain RPM range. A weld on the shield cracked and allowed the vibration.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
luvlabs
Frederick, MD
First off, it's not the engine, it's the chassis that you want to have a look at.
If it is not the heat shields, then rear end or drive shaft are the next two most logical things. You might want to contact your Ford dealer (it might take a while to find one who services motorhomes) and get it in for a diagnosis and repair.
2012 Tiffin Allegro 32CA
2012 Honda Fit
fla-gypsy
North Florida
Also possible hole or leakage in the exhaust system from the Y-pipe back through the cat converter or muffler.
Fiesta
Sherman, TX
My howl is from the Dana rear end. Typical and nothing to worry about. Pinion bearing wear.
jolooote
Miami, FL
Had a 2001 Geargetown, Ford F53 chassis that did it. Now my 2006 Ford F53 chasis also does it altho it has become much less after about 35000 miles. I'm guessing the rear end gears take a long time to 'Break in' and mesh more smoothly. I'd still have it checked by Ford if its still WARRANTY!!! If not warranty DON'T go anywhere near a Ford place.$$$$$$$ Find a good rear end shop.
Joe&Charlotte, Nat'l SurfSide DE34D Ford 362HP 5speed
Rusty, Rosie, Snuffy Dogs
Leroy's a Conure
If a 'Little' is good, 'Alot' ain't better.
hershey
Albuquerque,(fulltime) NM, USA
Does it have a tube grill? Tube grills will produce a whistle or noise. Fill with foam insulation to cure that problem.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
BillMFl
It is still under warranty and I'm taking it in on Monday. I don't think it is in the mechanical drive train because the sound quits the second I let up on the gas even though the RV is traveling at 70 or 75. The rear end and drive shaft would still be turning at high rpms. It is directly related to engine rpm but the sound seems just aft of the passenger seat area which is directly above the cat converter. Volume thru the exhaust is directly proportional to rpm, but I'm just guessing. Thanks for opinions. Hope to hear from a fellow V10 with similar sound.
traveylin
Rockport
On Monday you will have it checked by the ford dealer not the rv dealer that sold it to you right?
I had a hum at 60 mph last time out and traced it to the engine compartment hood not being locked down. It was not consistent but was affected by wind direction also
kedn
Ks
Does it flutter depending on your throttle position? I think your hearing "exhaust flutter". I had the same thing and the ford forums knew just what I was talking about, its just the way the stock y-pipe behaves and isn't a problem. Sure freaked me out as the first time I heard it I was about 800 miles from home.
'05 JayFlight 29BHS
'00 Excursion Limited, V10, 4.30
or
'01 F350 Crew Cab, V10
