RV.Net Open Roads Forum: Class A Motorhomes: Ford V10 howling sound
 > Ford V10 howling sound
Rochester, Mn
Posted: 01/25/13 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
In a MH, you shouldn't be able to hear noise from the rear differential over the "normal" noise of wind and engine up front.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 74,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
BillMFl
Posted: 01/26/13 05:50am Link  |  Quote  |  Print  |  Notify Moderator
OOOOOOHHHH NOOOOOOO! Somebody called me a whiner!
Order is illusion. Chaos is reality. But right or wrong I'm still the captain.
BillMFl
Posted: 01/26/13 05:52am Link  |  Quote  |  Print  |  Notify Moderator
OOOOOOHHHH NOOOOOOO! Somebody called me a whiner! (make mine a good stout Port please)
stephen hale
villa rica, georgia,usa
Posted: 01/27/13 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Had the same symptoms with a used 2011 motorhome I bought with 2500 miles on it with v10 ,dana rear end and Ford chassis. Ford had me take it to a local Ford dealer who replaced the differential. Didn't solve the problem so I took it to the Fleetwood service center in Indiana. By the time we got to Indiana the noise had quieted down some. Fleetwood said all of the Ford chassis have the whine or howl in different degrees because unlike cars the gears in trucks are unpolished.
On the way home to Georgia the noise got quieter yet and now I hardly notice it. See my past posts for responses to this problem.
s.m.hale
dkreuzen
Lake Havasu City, AZ
Posted: 01/27/13 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I had a new 2000 Excursion with a V10 and it had a vibration/noise at 2100-2300 rpm. Drove me crazy for almost three years because the dealer I bought it from could never find the problem. I moved to a another state and took it to the dealer there, demonstrated the problem so they knew exactly what I was talking about. They had it for two days and found that Ford had a replacement Y-pipe to repair the problem. After that never had the vibration again.
Dennis
2012 Monaco Knight 36PFT
2012 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon
rgatijnet1
Posted: 01/27/13 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I will not dispute your results but I must add that my Workhorse W-20 chassis also uses a Dana differential, as do most WH chassis, and it never had the rear end howl.
Now to further examine what you were told, especially about the gears NOT being polished. Let's assume that what he is saying is correct. Does that mean that as your gears ARE polished through use, that gear metal is being ground off and those metal particles will find their way into the bearings, etc? I mean if the gears have to wear in to be quiet, then metal MUST be shaved off in the process.
All differential gears that I have seen are polished where the gears make contact. When properly adjusted, through the use of shims, the gears make contact in the center of each gear and the noise is minimal. During production, it sounds like Ford/Dana is cutting some corners and guessing at the exact adjustment during manufacture and sticking them into a motor home/truck for the new owner, or dealer, to figure out. Sometimes they guess right, and the customer is happy. Sometimes, as in the case of the OP, they guess wrong, and the rear end is noisy. There is a short break-in period with most differential but I would guess that it should be less than 500 miles.
In your case, if the rear end is still getting quieter, after several thousand miles, I would have to assume that there are a lot of metal particles floating around in your fluid that came off of the gears. I would also assume that if it was so tight to begin with, that it MAY have overheated the differential in the initial few hundred miles.
Here are some links: Dana gear adjust
Differential adjustment
JoeH
Apollo Beach,FL
Posted: 01/27/13 10:45am Link  |  Quote  |  Print  |  Notify Moderator
On our v-10 MH, I had a similar noise.... would start about 65mph or so, very annoying . It turned out to be the idler pully bearing for the serpintine belt.
BillMFl
Posted: 01/28/13 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Well today me and a Ford Tech test drove the rig and agreed the noise was definitely coming from the rear axel. I got to walk to the rear of the coach while he drove (a first for me as my wife doesn't drive). They are going to install new gears. Drive train warranty with Ford is 5yr/50 and its covered.
jerseyjim
New Jersey
Posted: 01/29/13 03:44am Link  |  Quote  |  Print  |  Notify Moderator
GOOD FOR YOU!
rgatijnet1
Posted: 01/29/13 05:35am Link  |  Quote  |  Print  |  Notify Moderator
That's great news. Good for Ford to step up and take care of the problem rather than trying to tell you that the noise is normal.
