RV.Net Open Roads Forum: General RVing Issues: Portable air compressor
 > Portable air compressor
tvman44
Southwest Louisiana
Posted: 01/24/13 05:06pm Link  |  Print  |  Notify Moderator
I bought a good one from HF for about $90 that fills my 80 lbs tires fairly quick and if electricity is not available I simply crank up my Champion generator. [emoticon]
Papa Bob
Husky 16K hitch, Tekonsha P3,
Gale Hawkins
Murray, KY
Posted: 01/24/13 06:00pm Link  |  Print  |  Notify Moderator
brirene wrote:
This Craftsman fits my needs for a reasonable price. Fills my tires to 80# quickly.
We really like our 150 PSI Sears compress too. Saw the same compressor it at Lowes for same price with Porter Cable label. The closer to 2x of PSI needed by the tires the better I like it. Cycles between 125 to 150 PSI.
grandpaswagon
San Diego
Posted: 01/24/13 10:51pm Link  |  Print  |  Notify Moderator
http://www.homedepot.com/h_d1/N-5yc1v/R-........&keyword=makita+compressor&storeId=10051http://www.homedepot.com/h_d1/N-5yc1v/R-202713487/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=makita+compressor&storeId=10051
Check the reviews.
* This post was edited 01/24/13 11:01pm by grandpaswagon *
rhagfo
Portland, OR
Posted: 01/25/13 12:28am Link  |  Print  |  Notify Moderator
Just solved this problem, I am installing a Pacbrake exhaust brake and it comes with a 150 psi 12V on-board compressor and a 1/2 gal air tank. Line and fittings are provided to attach a 25' coiled air hoes to.
Russ & Paula
The Beagles Precious, and Belle.
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,Bilstein 5100's, 308,000 miles.
2005 Copper Canyon 293 FWSLS, 32' GVWR 12,360# GCVW 19,500#
Helmsey
Knoxville, TN
Posted: 01/25/13 08:44am Link  |  Print  |  Notify Moderator
MIL got me this for Christmas and I love it. I believe she found it at Kmart for around $75, not sure if that was a sale or not. The one thing I really like about this is the flow rate, 2 SCFM at 90PSI. I picked up a quick connect kit from Wally World and that helped with changing attachments.
I also carry a 7 gallon tank that this will fill to 120PSI with little issue.
KK4PFX
2015 Chevy 3500HD LTZ Dually
2013 Sandpiper 365SAQ
rdturn
Grain Valley, MO. USA
Posted: 01/25/13 08:52am Link  |  Print  |  Notify Moderator
Harbor Freight has them for $25. 150 PSI. Google them to find one in your area.
-Roger
2004 F250 SD Ford L/B
2008 FR Wildcat 30RL
Flinx777
Murrieta
Posted: 01/25/13 08:31pm Link  |  Print  |  Notify Moderator
After reviewing the postings, I think something like a MV is nice and small to not take up too much space or weight:
http://www.amazon.com/Master-Flow-MF-1050-Portable-Compressor/dp/B000L9AD2U
My only question is that I see it has alligator clips to clip onto a battery. Here's my question though: do I have to pop the hood and clip it to my truck batteries every time I want to run the pump? Doesn't seem overly practical. And how would I get it to reach my RV tires after clipping into the battery in the front of the truck? Just trying to make sure I get the right setup before I buy this.
2000 Ford 350 DRW 7.3L Turbo Diesel, 4 speed automatic, 4.10 rear end, limited-slip differential. Banks Power & Brakes, B&W Hitch
2007 Keystone Montana Mountaineer 34pht
cpaulsen
Oregon
Posted: 01/26/13 02:26am Link  |  Print  |  Notify Moderator
I have one from HF and paid 39.00 on sale. Works with my truck and 5ver for 80#s.
cpaulsen
time2roll
Posted: 01/26/13 11:55am Link  |  Print  |  Notify Moderator
I find that between the wire and hose length I can reach the tires without too much effort. Clip to the trailer battery if that is just as easy or closer to the tires. Yes you need to clip it direct on the battery as it draws more power than a cigar plug will handle.
I have seen a few posts where they remove the fitting from the compressor head and rethread to standard hose fitting. Then just attach what you like. The included hose does not fit standard air fittings.
Anyway the MV-50 has worked will for me as needed out on the road. The larger unit will fill even faster. I have a small (1.5gal?) 120v compressor at home.
675w Solar pictures back up
webslave
Clearville, PA
Posted: 01/26/13 11:58am Link  |  Print  |  Notify Moderator
Now you are beginning to see why many of us carry larger AC powered compressors with tanks.
Most portable 12v compressors are going to be alligator clip type designed to connect directly to the battery. These little guys draw a lot of amps (I have one of the marvelous Slime units that I carry and use with my ATVs - great pump) and due to this, they require heavy gage wires; not what you'll find on the "cigarette lighter" circuits. They use the alligator clips so that you won't plug it into a cigarette lighter socket and blow the fuse or set the wiring on fire. You will also find that many of these units run "hot". Small motors drawing large amps generate heat. That large amount of heat does three things; shortens the life of the motor, shortens the duty cycle (the amount of time the motor can run before you have to stop and let it cool down) and induces more moisture into the air stream (hot air carries more moisture than cooler air, that's why tanks have drain valves). The moisture issue isn't as important in Arizona, but, can be an issue in Florida and the Gulf states in the summer. And as you noted, they tend to be too short, both in power cable and air hose, not so "handy" for airing up your RV. They are designed for "emergency" use around your vehicle, not everyday use around the RV and campsite.
None of those obstacles are insurmountable... You can add a larger gauge (need to go up in wire size to account for extra length) power supply cable. You can re-engineer the air hose to be able to add a longer hose (most of these portable units use proprietary fittings; you can't just unscrew the hose and screw a longer one on). You can reposition your truck every time you want to air up the RV's tires. You can spend longer time airing up to let the unit cool down so that you don't exceed the duty cycle times. You can just let the water slosh around in your tires since the hot air as it cools will deposit the water inside the wheel over time. Or you can just deal with all the little foibles of the 12v portable air compressor and work around its shortcommings (wait for cooling down, reposition truck, etc). It can be done. Lots of people do it all the time and there is no real reason that you can't. I tried it that way, years ago, and for not very long...
The other alternative is to get a heavier duty, general purpose, AC powered compressor with an air tank. Runs on 110 and most have very long duty cycles. They use standard fittings available at any DIY center, auto parts store or Walmart. They have tanks that allow the moisture to cool out of the air before being pumped into your tires. As I mentioned, I have one of the Slime portables. A very nice 12v compressor, but, I only use it with my ATVs for emergencies; not as a multi-purpose compressor for the RV, truck and campsite or farm (I have a total of 8 compressors around the place). I use the aluminum, dual tank 120v compressor (I didn't pay full price for mine, either, I think I paid in that $130 price range, too). I have twin 25' self coiling air hoses that easily reach all of the tires and the neighbor's campsite if necessary and a tire inflater with built in gauge similar to this:
Tire inflator with gage
As I said, most, but not all, of the 12v issues can be overcome, or, you can spend a bit more and not have to deal with them at all.
My 2 cents, your mileage may vary...
Don
Bronwyn
Down to 1 kitty...J-Lo, the princess
2014 Thor Tuscany 40RX
2015 Jeep Cherokee TrailHawk Towed
