titleman
Jacksonville
I have new Artic Fox 29-5T on order from a dealer in Arizona that will come with 16" Aluminum Wheels with ST235/80R16 E rated Goodyear tires. I want to run GY 614 LT tires that are G rated. I am figuring the wheels that come on the trailer will not be rated high enough to carry this tire so I will have to replace both wheel and tires. Being that I live in East Texas, I will have to get them ordered and shipped to the dealer so that he can install them before I take delivery.
Can anyone advise me as to the different brands of Aluminum Wheels that are available and your opinion of the qualities. Also where I can buy them. I have never had to buy alum. wheels before, so need a little help. I know Alcoa makes them but am not aware of any other brands. All I do know is that they need to be 8 hole and 6.5 bolt pattern. I am trying to find out now if they will be 1/2 or 9/16 lugs.
Any help or info you guys can help me with will be appreciated.
Titleman & Pat
2013 Artic Fox 29-5T
2012 GMC 3500 Duramax
newman fulltimer
rv.net
discount tire or the tire rack call them give them what info you have they can order them and ship them the only other measurment you need is the offset
ford truck guy
Pennsylvania
Check with the manufacturer.. IF the G rated tires were an option at time of the order , the rims may already be rated to hold the 110 psi. Alot of the manufacturers will only stock the heavier duty wheel so when they upgrade the tires they do not have to stock a whole differenty inventory...
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
JIMNLIN
out here
http://www.trailerpart.com/
has quality Alcoa aluminum trailer wheels. They are located in Dallas. TX.
I've bought several sizes of wheels with them over the years. Great bunch
'97 Park Avanue 28' 5er 11200 gvwr two slides
tvman44
Southwest Louisiana
I would try to change the order so the new unit comes with the tires you want. Makes no sense to me to pay for tires and wheels and then pay again upon delivery. Has to be cheaper to order with what you want.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
donn0128
Pronounced Ore-gun
Personally I would contact Northwood Mfg directly and ask them if there was any way they could/would install 17.5 inch tires/wheels under that fiver. Going to GY G614's is IMHO going to bite you in the end. You will then be stuck with a single tire and tire source. Not a smart move in my way of thinking.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Cummins12V98
on the road
The wheels will be fine because you won't need anymore than 80psi to properly inflate the G tires for your load. Use the inflation charts, all will be fine.
Some will tell you you have to run the max air on the G tires 110# that is a bunch of Barbra Streisand!
Call GY Tech support they will tell you the same thing.
trailertiresandwheels.com is a great place to buy tires and wheels. They will sell tires and wheels separately or mounted and properly balanced. Also the tires will be fresh! He can tell you the mfg date. Ask for scott.
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
45Ricochet
North Idaho
Wow that floor plan is exactly like ours and the GVWR is about the same. I was kind of surprised at the weight.
Like Don suggested, I would also look into the 17.5 wheels and tires. Lots of options as far as rubber where the 16" you have basically one brand to choose from.
Enjoy the new camper!
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
smkettner
I thought the tires now had to be rated for the full GVWR... I guess not
675 watts solar
nremtp143
Georgia
http://www.tredittire.com/Default.aspx supplies a lot of wheels and tires to trailer manufacturers. In fact, on my new axles, I got my wheels from them. I too, run G614s and the wheels I got from them are rated at 3750 lbs just like the tires. Here is a pic of the wheels
They also carry 17.5 wheels and tires for trailers. Many around here have bought them from Tredit. 6k axles have 6 lugs with 1/2" studs, 7k axles have 8 lugs with 9/16" studs and 8k axles have 8 lugs with 5/8" studs.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
