RV.Net Open Roads Forum: Proper AGM Charging - help - battery specification gurus
 > Proper AGM Charging - help - battery specification gurus
Page of 5
HiTech
Posted: 01/25/13 12:02pm Link  |  Print  |  Notify Moderator
The specs for my Deka 8A27M Group 27 Marine batteries are:
Bulk 30% of C (20 hour rate) at 1.75 vpc (volts per cell) OR 6 times I20 at the same cell voltage (no idea what I 20 is?)
Absorption 2.35-2.40 vpc until charge in current < 0.10A per Hr/ Max Time 12 hour (I'm not really sure what 0.1 amp per hour means?? Is that .1 amp per amp hour capacity, or 9.2 amps for each of my batteries? Seems high?)
Float 2.24-2.26 vpc no time limit (Seems like a tight specification)
Equalize (!) 2.40-2.43 vpc until charge in current <0.10A per Hr/Max Time: 12Hr
Temperature coeff -3mV/cell/degree C
Minimum charge voltage limited to 35 C (95F), Maximum charge voltage at 15C(59F) -- I think this means to stop temperature compensating at the compensated voltage for these temps?
Jim
* This post was edited 01/25/13 12:26pm by HiTech *
enblethen
Moses Lake, WA
Posted: 01/25/13 12:05pm Link  |  Print  |  Notify Moderator
Ask Boeing about charging sealed AGM style batteries!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 01/25/13 12:40pm Link  |  Print  |  Notify Moderator
1.75 vpc seems low
I thought the research was pretty through on your selection...
675w Solar pictures back up
HiTech
Posted: 01/25/13 01:02pm Link  |  Print  |  Notify Moderator
Great point. 10.5 v seems very low. And it is basically a c/3 charge rate. Almost sounds like a stage before bulk rather than bulk like fork trucks run. I wonder if it is a typo.
Jim
sh410
Northwest
Posted: 01/25/13 01:14pm Link  |  Print  |  Notify Moderator
I thought they were lithium batteries?
bobojay5
Eastern Kansas
Posted: 01/25/13 01:15pm Link  |  Print  |  Notify Moderator
They are...
Bob & Sharon
Eastern Kansas
2013 Winnebago ERA 70A
Class B Van
MNtundraRet
Bloomington, MN
Posted: 01/25/13 01:18pm Link  |  Print  |  Notify Moderator
After the saleforce and lawers get together specifications always look like "Catch 22".
I bought my Optima Blue Top (Marine Deep-cycle) 50AH Battery 10 years ago. The first 5 years I recharged it with a Sears (Automotive) Automatic 10/2/50 amp engine start Charger. Battery was recharged 10 or 2 amp rate during that period.
Then I puchased my Schumacher SC-12000A SpeedCharger (2 amp, 15-40 amp multi-stage, 120 amp Engine Start). I re-read the pamplet on the Optima and said "To heck with that!".
The last 4 years were using the SpeedCharger to recharge the 50AH Optima Battery from a starting point of 20%(11.6v) to 50%SOC(12.1v) in 75 to 180 minutes. I quess many would call that "Torture" but the battery lasted 9 years. Much longer than I ever expected. The charger spent about 1/2 the time at 40 amps and rest at 15 amps. Multi-stage charger will go back and forth on current rate, and voltage rate, to keep cell temperature below maximum acceptable.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
mena661
Posted: 01/25/13 01:19pm Link  |  Print  |  Notify Moderator
Call them and get some clarification on that then report back. [emoticon]
Trojan L16 6V's 740 Amp-hours
Gale Hawkins
Murray, KY
Posted: 01/25/13 01:40pm Link  |  Print  |  Notify Moderator
bobojay5 wrote:
They are...
Is this the last Dreamliner fire issue?
enblethen
Moses Lake, WA
Posted: 01/25/13 02:03pm Link  |  Print  |  Notify Moderator
Yes!
There is some thought that the glass mats separating the ion compound failed due to charging problems or overcharging.
Page of 5
