RV.Net Open Roads Forum: Tech Issues: OH NO Silicon!!!
 > OH NO Silicon!!!
nmhuntr
Las Cruces, NM
Posted: 01/25/13 03:06pm Link  |  Print  |  Notify Moderator
OK I was ready to use the Dicor on my roof around the vents and along the front edge. The vents went great and I go to clean and prep the front edge and it has silicon on it.
It is all along the front and upon closer inspection it is also around the skylight. I guess the only option is to pull off all the silicon I can being careful not to cut the rubber roof and then use the eternabond tape to lap over everything??
At least I know why my antenna was not turning. The idiot used silicon around it as well up against the rotating piece [emoticon]
Ideas??
Thanks
* This post was edited 01/25/13 04:05pm by an administrator/moderator *
2005 Fleetwood Pioneer ASV 180FK
2008 Tundra
westend
Shorewood, MN
Posted: 01/25/13 03:58pm Link  |  Print  |  Notify Moderator
I had to remove a lot of it on my TT. I used a caulk remover made by 3M (sorry threw the bottle). The remover is applied to the bead of caulk and allowed to soak. In a few hours, the caulk is wiped away. Any residual silicone can be scraped with a plastic scraper and the area cleaned with a solvent.
Be sure to get every last bit of silicone off the surface before applying the Eternabond tape, it will not stick to any surface with a trace of silicone. FWIW, I sealed my entire TT and then did a pressure test. The only areas that had no leaks where the joints covered by Eternabond. It is a great product!
'03 F-250 4x4 CC
Camp, Forrest, Camp!
Boise, ID
Posted: 01/25/13 04:16pm Link  |  Print  |  Notify Moderator
Teach me something new. What's wrong with silicone? I thought it was the preferred material for sealing joints on RV's.
-2000 Chevy K3500 CC DRW 7.4L, Auto; 2000 Arctic Fox 1150 WB; 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust.
Boise, ID
Posted: 01/25/13 04:17pm Link  |  Print  |  Notify Moderator
MEXICOWANDERER
las pe├▒as, michoacan, mexico
Posted: 01/25/13 04:32pm Link  |  Print  |  Notify Moderator
Contact 3M for the best way to remove silicone without damage.
I am still wayne_tw
everywhere
Posted: 01/25/13 04:36pm Link  |  Print  |  Notify Moderator
Be very very careful with this approach. Most solvents and probably that caulk remover contain petroleum products which ruin a rubber roof!
harold1946
surprise Az.
Posted: 01/25/13 04:37pm Link  |  Print  |  Notify Moderator
Silicone sealant is not recommended because when it comes time to reseal, nothing will adhere to it, not even more silicone. It is very difficult to remove and has to be completely removed before resealing.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
mockturtle
WA
Posted: 01/25/13 04:38pm Link  |  Print  |  Notify Moderator
Silicone is good for everything but rubber, is my understanding. It is flexible, doesn't dry out and is long lasting. Yes, it's a bugger to remove.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
ktmrfs
Portland, Oregon
Posted: 01/25/13 04:39pm Link  |  Print  |  Notify Moderator
NEVER NEVER on a membrane roof!!!! that's what Dicor or eternabond is for.
And second, most silcone's you buy at the local hardware store don't adhere well to metal or filon. the best sealers are available from RV stores or marine supply stores and are designed to adhere to the siding and plastic well. The best ones that I have found may not even be silcon based AFAIK.
2011 Keystone Outback 295RE
nmhuntr
Las Cruces, NM
Posted: 01/25/13 05:00pm Link  |  Print  |  Notify Moderator
Can I just lap the êternabond over everything after I pull as much silicon off as possible?
 > OH NO Silicon!!!
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
