RV.Net Open Roads Forum: Fifth-Wheels: Surge protector theft prevention?
 > Surge protector theft prevention?
Texas Two Steppers
Beaumont, TX
Posted: 01/26/13 05:35am Link  |  Quote  |  Print  |  Notify Moderator
I use one and carry a lock and key and lock the electrical box after plugging in. There is usually a hole in the door that lines up with a hole in the base that is made for locking in most meter boxes. I have found that you can do this about 75% of the time. For the other 25% I carry a chain to loop around the cord then around the pedestal. Never had an park complain about me locking their box.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
Bumpyroad
Virginia
Posted: 01/26/13 05:56am Link  |  Quote  |  Print  |  Notify Moderator
bob213 wrote:
TRC Surge guard sells a box that goes over their unit that will let you run a cable thru it. Progressive industries EMS has a tab on the cord that let's you run a cablet thru to lock it up.
trc surge guard lock
does that go over the whole unit or just over the plug? if just the plug it is a joke IMHO. I used epoxy and glued a padlock hasp onto the side of mine. they can crack the case open to steal it if they want to.
and do NOT get the 90$ jobby, get a multi function one that protects from over/under voltage, spikes, delay on reset to protect AC compressor, etc.
I just put mine in a basement compartment out of sight, out of mind. but if you get a hard wired one, be sure it has a bypass feature.
bumpy
lakeside013104
Houlton,Maine
Posted: 01/26/13 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Miles Away....
steel cable device that crimps tightly around the male end of the power cord and another that crimps around the female end of the surge protector
Picture please.
Thanks.
lakeside
USMC veteran 1969 and proud of it
2014 Bighorn 3685RL - Hensley TS3 air hitch
2011 F-350 4x4 Lariat Super cab 6.7 diesel SRW
bob213
Fresno, CA
Posted: 01/26/13 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
bumpy
Bumpy, It goes over the unit. I agree it not theft proof but I was taught " a lock does not keep a theif away, it just keeps an honest person honest." I figure if I make something harder to get, they will look for an easier one to steal.
Bumpyroad
Virginia
Posted: 01/26/13 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
bob213 wrote:
bumpy
if that makes it possible to lock up the entire surge protector, it should send thieves elsewhere.
bumpy
Lantley
Ellicott City, Maryland
Posted: 01/26/13 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
If your concerned about theft get a hardwired unit and be done with it. I chose to go the hard wired route as a matter of convenience.
No set up no locks etc. Theft avoidance is just an added benefit.
I do not think theft of portable units is a big deal
This is my first season with a 50 amp hardwired unit. On my next to last trips the unit discovered a mis wired outlet and would not apply voltage. The outlet was defective.
Fortunately I was able to plug into another nearby 50 amp outlet using my 50 amp extension cord (another item that you never know when you might need it!).
In my case the surge suppressor worked as designed and I avoided any potential damage.
In my mind it only takes one damage saving event for the surge to pay for itself. From here on out I consider myself ahead of the game.
* This post was edited 01/26/13 01:03pm by Lantley *
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
RCFROMFL
CENTRAL FLORIDA
Posted: 01/28/13 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
To all that responded with their application, what about including a photograph for the "dimmer" lights on the RV network.
WoodGlue
Los Angeles / Montana
Posted: 01/28/13 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
At home, I hook my computer and my TV and electronics into a surge protector, so it's like a no-brainer that when I go camping with my RV, that I'd do the same thing!
D'oh!
To me, it's not about theft as I'm not too concerned and put the dealie up inside the box at the pedestal.
WoodGlue
2002 Land Rover Discovery II
2013 LANCE 1685 Travel Trailer - Video Tour - Video Tour 2
Lance Uses Azdel - Why It's Better Than Wood In Your RV Walls
There Are 84 Less Chances Of A Roof Leak In A Lance
Lance Factory Tour
2014 LANCE 1685 - Due July 2!
ryhed
West
Posted: 02/04/13 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
A security camera and a .45. on another note, would it be possible to wire your cords to a european style plug with the us plug in on one end rendering it useless to anyone who hasn't modified their plug ends? I also came upon this in a search,
http://www.parvonisresearch.com/product/tech_desc.shtml
