goducks10
Keizer OR
AF is heads above the Lance. Take a look at the Lance frame. AF will take more abuse.
LewBob
Lebanon, CO
WoodGlue wrote: LewBob, which model of the Lance were you looking at?
Thanks,
WoodGlue
The 1685.
Lew
2011 Arctic Fox 22H
2012 Ford F-150 XLT SuperCrew 4x4 EcoBoost
"Wish I didn't know now what I didn't know then."
--Bob Seger (Against the Wind)
WoodGlue
Los Angeles / Montana
coolbreeze01 wrote: They both make truck campers. I'd see what owners have to say in that forum also.
X2 on this suggestion!
2002 Land Rover Discovery II
2013 LANCE 1685 Travel Trailer - Video Tour - Video Tour II
Lance Uses Azdel - Why It's Better Than Wood In Your RV Walls
There Are 84 Less Chances Of A Roof Leak In A Lance
Lance Factory Tour
WoodGlue
LewBob wrote: The 1685.
It took me 2 years of research before I pulled the trigger on my 2013 Lance 1685.
What sold me on the Lance was the lightweight aspect in that they use Lite-Ply instead of traditional plywood and Lite Ply is almost 50% lighter iirc. The cabinets are all faced with traditional wood imported from Spain, tongue and groove.
At 4:40 on the video, see what Lite-Ply weighs against traditional plywood:
Lite-Ply vs Traditional Plywood
Also pinch-rolling the fiberglass in the walls instead of vacuum bonding is the crux at not getting the delamination that so many vacuum bonded units get, in my opinion.
WoodGlue
** edited to make correction
last
edited 01/25/13 09:37pm by WoodGlue *
View edit history
donn0128
Pronounced Ore-gun
sbowman871 wrote: LewBob wrote: donn0128 wrote: Even with an ecobooat your going to be severely limited if you go with a fox. They are just plane heavy. I would not consider anything over about 22. Feet with your setup.
We have the heavy-duty tow package rated for 11,500 pounds gross.
How heavy is a A Fox?. ...(fellow ecobeast driver. )
What i will say is that if you are looking at the dry weight numbers you will be on for a real shock. When all is said and done you will be bumping right up against the trailers GVWR numbers. There are many reasons for that, including construction and frame design. Northwood has a reputation for decent quality at the price of weight. Go over to afnash.com and ask some questions to verify my comments. I owned a rather small fox 19b and compared to other trailers of that size it was way heavier. You will be hard pressed to find a company that supports their products any better than northwood, and being one of the last privately held companies you are dealing with family, not a big comglomerant.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
mrkoje
Great Falls, MT
I have the OutdoorsRV backcountry 26fs. The construction is absolutely amazing for a camper. It's built on a northwood frame and is very 4seasons capable. A step up to the creekside and you can get some nice floor plans for full timing. Their are two other lines as well from OutdoorsRV which are Timber Ridge and Blackstone though they are high dollar units 35k+++
If you are looking at something to live in while bing in cold climates you can't go wrong with the Northwood lines including the OutdoorsRV group as well.
Happy camping!!
edited 01/25/13 10:35pm by mrkoje *
TT 2013 OutdoorsRV Back Country 26FS
TV 2012 Ram 2500 Crew 4x4 Outdoorsman SB 6.7L CTD
WoodGlue
I might also add that the Lance uses Azdel substrate, a material in place ot Luaun wood, which furthers their walls and floors weight lessness and compounds the walls and floors and roofs strength!
Azdel deserves credit for being the super material it is in the Lance Camper & Trailer.
WoodGlue
2wiresdave
Right here
I just went through the exact same shopping criteria. I have a 2011 Ford F 150 Eco boost with max tax package. Truck can "tow" 11,300 pounds... But runs out of capacity real quick when looking at tongue weight and payload etc.
The Arctic Fox is a better trailer from a simple construction and insulation standpoint. Stand in both a Lance and a Arcti Fox and look up at the roof vents. The Fox is obviously hiding a lot more insulation. The frame is dramatically beefier.
That said, I bought a Lance 1985. Liked the layout and some of the construction materials etc. I would have bought the Arctic Fox if I had enough truck to tow it, but can't justify the expense of a 3/4 ton truck at this time ( current truck is only 2 years old)which you honestly need to tow an Arctic Fox in any of the slide models. We had a tough time choosing whether to go with an Arctic Fox 22h - any bigger and we would be maxing out the truck which I don't care for or the Lance with a slide and staying well within capacities of our vehicle.
We are pleased with the Lance so far, have almost 30 nights in it so far. Will put around 90-100 nights a year in the trailer.
An Arctic Fox 5er is our future after we get a few years out of the Lance, truck combo.
Have fun shopping!
Padlin
W. Ma.
If Lewbob has the HD F-150 he has enough payload capacity, mines 2200 lbs including me. If he has just the max-tow without the HD then he'd have to stick with one of the small units.
Personally I like the the lance 1685 floorplan over the 22' AF's if those are what you're looking at. The bump out is awfull nice in a small trailer. Lance did a good job with all their layouts. The Lance 2285 with the swivel recliners vs the AF 25W with recliners is another tough choice. They are all nice, have fun.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
06 Starcraft 18SB
RVcrazy
Puyallup, WA, USA
No comparison for durability. The Fox wins.
