Texas Two Steppers
Beaumont, TX
I ordered the B % W Companion 3000 and had the 1012 gooseneck installed and did the hitch myself. It looks good in the truck. Now for the hard part. There are like 6 adjustments on the hitch and 3 on the pin box. I have tentatively set it in the middle/highest position. Since the rig is new I will first load it and then level it when hooked up. Next I will go to the scale and weigh everything including each rv axle. I think the ideal posture of the rv is slightly nose down with each axle carrying about 50% of the load. If I can do it on the scale I will weigh the tires one side to get the side to side weight distribution. On most Cat scales I have used you have to have weight on the 1st scale and there is usually a header there so you can't do just one side.
Since we are at home base I will probably allow 1 day which means my wife will HAVE to go to the mall.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
nremtp143
Georgia
Welcome to the B&W family. No other hitch comes close! And it's made right here in the USA!!!
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
campfire4258
SC
Love my B & W W/ Companion.
campfire4258
2012 Dodge Ram 3500
2009 Montanna Fifth Wheel
laknox
Arizona
nremtp143 wrote: Welcome to the B&W family. No other hitch comes close! And it's made right here in the USA!!!
X3! FWIW, my hitch is set as high and as far forward as it will go. I wanted it that way. I do tow a touch nose high, maybe 2-3", but the 8+" bed clearance I get is necessary for when we boondock in our usual spot. I wanted it as far forward to get as much weight to the front as possible. Even then, the center of the king pin is only about 2.5" in front of the centerline of the rear axle, per a phone call to B&W asking that question.
Lyle
1936 John Deere Model A
drfife
Dallas, Texas, USA
Gary, with your new truck I would set the B&W at the middle height, most forward position.
That should be about ideal for your Winslow.
Russell
'12 GMC Sierra 3500HD Duramax Z71
'13 Excel Winslow 34IKE
Cummins12V98
on the road
Set it to where you have 6" bed rail clearance minimum and full forward.
Go to the scales and see what each axle weighs. Adjust as needed.
Mine is full forward and with 4,500# pin weight only 100# transfers to the front axle.
Never have heard of or seen bed rail damage with a B&W hitch in the bed!
2011 Ram Laramie Longhorn 3500 Dually Long Bed, Cummins 350/800 HO, Towin Machine
B&W Companion Hitch, Maghytec Trans and Rear Dif Covers, AMZ/OIL Top To Bottom
2007 1/2 Mobile Suites 36 SB3 27,000# Combined
nremtp143
Georgia
I have mine in the far rearward position and as high as possible. I changed it from the middle to the rear and reweighed it, the front axle lost 10 pounds. The reason I moved it back is so I can carry the bikes and have them miss the toolbox when it opens. Most people say not to use it this way, but the center of the pin is only about 2" behind the center of the axle. It has worked for me.
mudmaker
Iowa
When you get it set I would like to know the bed height unloaded and your clearance when you finally get done. I know it won't be exactly the same as mine, sb vs. lb but it would give me some starting numbers so I can adjust from there.
Glen and Loretta
Marc, Jake, and Kirsten
Keystone Cougar 326MKS
2013 GMC Terrain
12 Silverado 3500 SRW quad 6.6 Dmax
03 Dodge 3500 DRW quad 5.9 cummins
Yamaha EF2400is gen
Texas Two Steppers
Beaumont, TX
mudmaker wrote: When you get it set I would like to know the bed height unloaded and your clearance when you finally get done. I know it won't be exactly the same as mine, sb vs. lb but it would give me some starting numbers so I can adjust from there.
I will post the numbers when I get them and let you know. I just got it loaded and am a full-timer so it will stay loaded.
Tango, AE7UI
Taylorsville, UT
My B&W hitch is installed as far forward and as low as posible.
I am still a little nose high but it tows like a dream.
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
