RV.Net Open Roads Forum: Where can I buy this 12 VDC plug?
 > Where can I buy this 12 VDC plug?
Mark Heisler
Viking,Alberta Canada
Posted: 01/26/13 07:50am Link  |  Quote  |  Print  |  Notify Moderator
make one
heavey wire
yellow wire spades
red and black elec tape
replacement battery charger clamps(black and red)
I had one for my honda gen the factory one it worked.you are better to buy a small but good battery charger works way better.
* This post was edited 01/26/13 08:06am by Mark Heisler *
2003 dodge 2wheel drive diesel 375hp 750torque
2007 citation fifth wheel model 29bhs
RJsfishin
Winston Or.
Posted: 01/26/13 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Oh well thats a different story !
Get after it,.....have the fun !
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
Ron3rd
Upland, CA USA
Posted: 01/26/13 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Like others said, you'll be fighting the low amperage output of the 12v charging port on the Honda Genny. Yes, it will work but will be slow. Much better to use an external "real" battery charger connected to your Honda or even the charger/converting in your RV; both are better than the 12v outlet on the genny.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
stevekk
CA/ OR border
Posted: 01/26/13 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks... Good to know.
I am new to RVing.
Just bought my first RV less than a year ago.
aruba5er
Neenah Wisconsin
Posted: 01/26/13 08:15am Link  |  Quote  |  Print  |  Notify Moderator
I made one just take a 2 wire plug and a needle nose pliers and twist. Mine works just great. Seconds on the battery charger. It'll work better than the Honda
prairie camper
West St.Paul, MB, Canada
Posted: 01/26/13 09:08am Link  |  Quote  |  Print  |  Notify Moderator
I have the same gen, like so many have already said get a good battery charger and use that!
sh410
Northwest
Posted: 01/26/13 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Or, you can plug your shore power cord into the Honda.
RoyB
King George, VA
Posted: 01/26/13 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Here is a better photo for my 2KW Honda EU2000i generator
sample photo from GOOGLE images
As noted above this output is only 12.0VDC and at 8AMPs.
This will not re-charge your battery in a timely manner... Would probably take about three days or more to re-charge to 90% charge state. You might think the battery is getting charged in a couple of hours but when you try to use the battery it will deplete itself rather quick. Your 12AMPS will take a little shorter time but not much.
The best approach is to purchase a smart mode technology battery charger like the Black and Decker VEC1093DBD 40AMP portable unit and run it from the 120VAC receptacle of the generator front panel. This will re-charge your battery in about three hours generator run time. I use this large of a charger as I have multiple batteries in my bank. You can use a smaller output type charger like the 20AMP or the 10AMP model but if you want to re-charge a single battery to its 90% charge state in a short three hour generator run time you will need the 20AMP model at a minimum.
Consider this white paper report from Progressive Dynamics on how long it take to re-charge a deep cycle battery.
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
This a battery science - no tricks involved here...
You will need 14.4VDC at around 20AMPs to re-charge a deep cycle battery in a three hour time period using smart mode charging technology.
My Honda 2KW generator has that two conductor receptacle on it as well but I have not found anything useful for it yet. Maybe a portable light to be able to see what you are doing in the dark...
I just typed into google '12VDC ChARGING CABLE FOR HONDA GENERATORS'
When it loads up select "IMAGES"... Many sources found like this one... Click on the one you like to see the source.
HONDA 12VDC CHARGING CABLE - LARGE CLAMPS - 10 FEET
Manufacturer: Honda
Model: 32660-894-BCX12H
Price: $15.99
Roy Ken
* This post was last edited 01/26/13 10:26am by RoyB *   View edit history
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Wherever I happen to park
Posted: 01/26/13 11:25am Link  |  Quote  |  Print  |  Notify Moderator
From any honda dealer.
However save yourself grief, Don't bother, that 12 volt outlet is not much good for anything, Not enough current to reasonably charge a battery, No filtering or regulation, it is good for a 12 volt lamp and that is about all.
stevekk
CA/ OR border
Posted: 01/26/13 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Roy and everybody else.. very informative.
So what would I use the jumper cables for?
I guess small 12 v appliances, TV, outside lights, etc?
Wonder why Honda had a special plug, vs just having the standard cigarette lighter plug?
Probably will purchase the batt charger you recommended to carry in my MH.
