RV.Net Open Roads Forum: General RVing Issues: Battery Tender and Water Consumption
 > Battery Tender and Water Consumption
K3WE
Missouri
Posted: 01/26/13 07:00am Link  |  Quote  |  Print  |  Notify Moderator
For those that use a battery tender- what do you find the water consumption to be?
Thanks.
rrupert
NW PA
Posted: 01/26/13 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I have a Battery Tender Jr. on my John Deere tractor that is left on all winter. I haven't had any noticeable drop in acid level.
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
tvman44
Southwest Louisiana
Posted: 01/26/13 07:48am Link  |  Quote  |  Print  |  Notify Moderator
None with mine.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
georgelesley
Minnesota
Posted: 01/26/13 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I use two for the MH and one for the ATV. Water use is virtually non-existent.
George & Lesley
2013 Winnebago ERA 70A
Dave H M
IL
Posted: 01/26/13 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I got 4 running in the barn.
Zero water addition needed
beemerphile1
I'm 57, I'm not a
Posted: 01/26/13 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Deltran Battery Tender is a brand of charger/maintainers. Not knowing which model you have the most common is probably the Plus which is a maximum of 1.5 amp output. At 1.5 amp you should have no discernible water loss.
I have the Plus and the Jr. and have no noticeable water loss.
- Soren Kierkegaard
Gale Hawkins
Murray, KY
Posted: 01/26/13 11:18am Link  |  Quote  |  Print  |  Notify Moderator
They cause NONE. Even the high voltage float on our 20 year old Magnetek converter does not cause water loss UNLESS the batteries are starting to die.
8ntw8tn
Southeast Iowa
Posted: 01/26/13 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
Our motorcycle is on a battery tender year 'round whenever it's not being ridden and our other vehicle is on one while we're in Texas for the winter. We've never seen any water depletion on either one of them.
'04.5 Dodge Ram 3500 Quad cab 4x4 SLT dually w/5.9 H.O. Cummins; PacBrake; Smarty Jr.; Raptor 100 lift pump; egt & tranny temp guages;rebuilt tranny;
'06 Carriage Cameo LXI F35CKQ w/MorRyde pinbox
Det 1 56th SOWg
