RV.Net Open Roads Forum: General RVing Issues: running hot water heater
 > running hot water heater
davidbt
Sonoma County
Posted: 01/30/13 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
First time posting. We just bought a 5er from a kid who was moving from a permanent rv sight we were looking at. My wife and I were debating wether to leave the hot water heater on all the time or just turn it on when were going to shower or do dish'es. New to posting. Thanks
2oldman
Wilson Creek WA
Posted: 01/30/13 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
leave it on
GaryWT
MA
Posted: 01/30/13 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
We turn ours on when we arrive and off when we are leaving. Did it when seasonal and now when we travel.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR
ScottG
Bothell Wa.
Just like at home, leave it on unless you have to conserve for some reason.
Scott, Grace and Wesly
H0NDA eu2000i
korbe
Northern California
Posted: 01/30/13 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
We normally only need hot water once or twice a day. We turn it on a little before we need it. No reason to waste LPG.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
pianotuna
Regina, SK, Canada
Posted: 01/30/13 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Welcome to RVnet!
If the water heater runs on propane it is better to turn it on 30 minutes before a shower, then turn it off. There may be enough hot water left for the rest of the day for hand washing and dishes.
If the water heater is electric and propane, and electricity is included with site rental, leave it on the electric only setting.
If you are paying for the electricity, then I'd turn it on with both propane and electric 30 minutes before the shower--then turn it off.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
nineoaks2004
Posted: 01/30/13 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
I turn mine on when I arrive and off when we leave..When it gets hot the burner shuts down until the water cools down then fires back up. The propane it uses is minimal
Expect the worst, Hope for the best,
settle for whatever comes in between
robsouth
Near Atlanta, GA
Posted: 01/30/13 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
X2
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
pianotuna
Regina, SK, Canada
Posted: 01/30/13 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
A ten gallon heater will cycle, if no water is drawn off, about every four hours and run time is about 15 minutes. Run time to fully warm the tank is about 30 minutes. Leaving it on will use far more propane, than turning it on when hot water is needed.
Gene&Ginny
North Kingstown, RI
Posted: 01/30/13 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
While it may seem obvious to say, only run the water heater when using the camper and have water in the tank.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
