Donniecfd32
Franklin Township
I've had this issue with our "08" Silverado Dmax/Allison since it was new and I was wondering if anyone else has/had this issue. These trucks have a small fuel tank to begin with (26 Gals.) Problem is that our fuel tank still has 6 or 7 gallons of fuel left when the gauge hits the Empty mark and the low fuel light comes on and the truck will only take 14, 15 gallons of fuel. Now I use the DIC gallons used instead of the gauge and it works our very well. I was just wondering if this was a problem with my truck or does anyone else have this issue?
Donnie & Shawn
2008 Silverado 3500HD D/Max Allison
2013 Dutchmen Voltage 3200 Epic
2003 Harley Davidson Roadking Classic
1998 EZGO Golf Cart
newman fulltimer
rv.net
on most chevy fuel guages if you turn the key to the on position without cranking it will show the true level
Donniecfd32
Franklin Township
Interesting to know. Don't see much use for that though as it's more important to know your true fuel level while you're driving down the road. I've had a "99" and a "02" and nether one of those had an issue with the gauge showing true, however those were both gasser's and our current truck is a diesel. I'll have to give that a try the next time she needs fuel.
msjdbman
SW Michigan
My 08 DMax is the same way. It is annoying, but I just set the DIC to gal used and run it down from there.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
2003 Coachmen Chaparral 295 IKS
Bull Rider
Washington, The State
I have the 06 Dmax, and I pulled out the stock tank and had a 52 gallon Titan tank installed. I use the DIC to monitor the fuel used. The stock tank is way too small for towing. I can tow for 8 hours before needing to fuel up.
After a little while, it seems like the DIC has figured out that there's a bigger fuel tank. Best mod. that I've made to the truck.
rodknocker
Baton Rouge LA 70817 USA
There is a simple re-calibration for the fuel gauge. Check Google, bet you could find something.
Craig and Cheryl with our dogs
Cooper (GR), Sally (English Springer)and Charley (King Charles Cavalier)
'06 Chev Duramax LBZ
'03 Jayco Designer Legacy 3610 RLTS
Bill T
upstate sc
Mine is the same way, also just use the gals. used.
On the Duramax diesel foreum some say it is a built in safety feature to encourage you to fill up before running out of fuel since it is harder to restart a diesel.
Bill and Debbie
2007.5 SILVERADO HD DA CREWCAB LTZ 4X4 ARE CAP
2003 Nash 25S TT
2012 Lance 855S
1996 Coleman Taos pop-up
1970 jeepster,v-6
donn0128
Pronounced Ore-gun
That is done on purpose. Have you ever run a diesel completely out of fuel?. It is not a fun place to be in. Trying to get the fuel system bled out can be a real hassle. Especially along side the road. Your beat option is to replace the factory fuel tank with an aftermarket lager one.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
newman fulltimer
rv.net
hey don surprised you did not just say buy a dodge
Donniecfd32
Franklin Township
Nope I've never ran out of gas or fuel. I fill my truck up after each use. and all my vehicles at 1/4 tank. I guess driving a fire apparatus for 25 years ruined me. I could see why the factory would do this though. priming the the engine after running our of fuel would be a real pain. It's bad enough reaching in there to prime the filter after changing it. It's not a big deal I've gotten use to just running off the gallons used. I was just wondering if my truck was an odd ball or if they all were like that.
newman fulltimer wrote: hey don surprised  you did not just say buy a dodge
I figure to each their own, but I'd rather push my Chevy rather than drive a Fiat. :-)
