knesdad
Wisconsin
Anyone else with a 2012 F150 getting a constant squeek from one of the front brakes? I get it all the time on the front left brake, especially when backing up. And it does it all the time, regardless of weather conditions. I had it in twice and the dealer ground it down some, but insists it's from rust build up from the dampness. Then they told me it could be from the lighter brake material Ford is using to keep the weight down. Hunh???
Thanks.
Dave.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
We are. I've taken it back twice so far.
2012 f150 Ecoboost
rightyouareken
Seattle, WA
Mine does it very occasionally backing out of my steep driveway. Never when going forward. Not sure which wheel(s) it is. My wife's Nissan Murano does it worse and the Nissan dealer hasn't been able to fix it. Doesn't seem to cause any other issues so I ignore it.
2012 Ford F150 FX4 5.0 3.73 SuperCrew Short Bed
2013 Jayco JayFlight 24FBS, Equal-i-zer 1k hitch
WVbassmistress
WV
We had a 2007 F150 that did the same thing. Forwards and backwards. It was really loud and VERY EMBARRASSING!! We had it in the shop numerous times including grinding them down. Did it even after having pads and rotors replaced. The next step was to get the premo, most expensive aftermarket, but traded for an F250 instead. Keep us updated if you find a cause...I am really interested.
Lisa, Bobby & Dorothy the Wonder Dog
2013 F250 crew cab/6/5 foot bed
2003 Palomino B800
Ranger Z518
22 ft Suntracker Pontoon
midnightsadie
ohio
my daughters van did this from day one after 7k they changed the cheap rotors and put good one,s on .call the hot line insist on new rotors.
knesdad
Wisconsin
WVbassmistress wrote: VERY EMBARRASSING!!
To say the least!!! My kid's friends can hear it 3 houses away when they are waiting for the bus in the morning! They nicknamed my truck "Squeek"...
msjdbman
SW Michigan
My 2013 F-150 has squeeked from the RF wheel while in reverse each and every morning upon backing out of garage only, since about 2500 miles. I now have nearly 8000 miles and the condition is unchanged.
2008 Duramax/Allison LT2 Crew cab Standard Box. Hellwig Air Assist.
2003 Coachmen Chaparral 295 IKS
knesdad
Wisconsin
msjdbman wrote: I now have nearly 8000 miles and the condition is unchanged.
I just turned 11,000 miles on mine...
