RV.Net Open Roads Forum: Fifth-Wheels: can we pull this fifth wheel
 > can we pull this fifth wheel
Kentucky_Joe
Fort Thomas, KY USA
Posted: 03/23/13 12:42pm Link  |  Print  |  Notify Moderator
Looking at a half ton tolerable fifth wheel - cougar rks 2013 we have a Silverado 1500. We have 2wd. Our truck states we have the 5.3L v8 with the 3.73 axle. We have a crew cab with a short bed. It says 7600 lbs maximum trailer weight. Gcwr states 13,000 lbs. The cougar states 7000 shipping weight. 3000 carrying capacity. 1230 hitch weight. Can someone please help me figure this out. Want to make sure we will be ok pulling this.
Krease
The Lowcountry, SC
Posted: 03/23/13 12:45pm Link  |  Print  |  Notify Moderator
You won't be OK pulling it. I'll be nice, some here won't.
2011 Ram 3500 Longhorn H.O. Megacab DRW
2012 Montana 3750FL
Golden_HVAC
Fulltime, CA, USA
Posted: 03/23/13 12:54pm Link  |  Print  |  Notify Moderator
The truck weight capacity is probably not suficient to carry your family and a additional 100 pound hitch and 1230 pounds hitch weight. You are looking at one of the lightest fifth wheels, and all of them probably will have a 1,000+ pound pin weight while empty, that should go up by 250 - 400 pounds when ready to go camping. This is because the water tank is normally between the axles and hitch, so it will add about 1/2 or more of the water tank weight to the hitch.
With a 50 gallon tank, this is 400 pounds. If the fresh water tank is 1/2 way between axles and hitch, then about 1/2 the weight will go on the hitch. If the tank is below the bedroom or bathroom, then more like 300 pounds will go on the hitch.
You might want to check the specs on Lance fifth wheels. You might not have a local dealer, but check out the weights online. I think they are fairly light too.
The problem is you probably have a 7500 GVWR and the empty truck is somewhere around 6,000 - 6,500 pounds empty. Add the family, and you don't have enough cargo capacity for everything. You really need to take the truck to a scale, and see what the weight is with a full tank of fuel.
WHile a 7,000 pound fifth wheel might have a 1,500 - 1,800 camping weight on the hitch, a conventional 7,000 pound trailer should only have between 700 and 1,100 pounds on the hitch, so much easier on a 1/2 ton truck.
Some of the Max Tow equipped Ecoboost F-150's can tow a fifth wheel, because they have a 2,300 pound cargo rating.
This is why you need to check the empty truck weight. With that, you will be able to figure out what you can tow. ALso post the GVWR found on the drivers door post.
Good luck!
Fred.
tanman32225
Jacksonville, Florida
Your pushing the envelope especially once you load down the camper. Does that mean it will not pull it. NO.. Your just going to exceed the load rating of your vehicle depending on how much you load it down. All vehicles have a built in safety factor that exceeds the listed weights.
Your fifth wheel pin weight is going to be somewhere between 1500 and 2000 depending on how its loaded. Your truck is going to squat in the rear a bunch. Maybe to the axles. You may need airbags to keep it off the axles. Your gonna need spring over shocks at minimum.
Your probably going to overheat that 5.3 pulling all that weight. Your transmission will shorten in life.
Basically I would say NO however my brother pulled a larger one than yours for several years with a F150 4x4 and only had problems in the mountains. Other than that it did pull the monster. I hope this helps.
Desert Captain
Tucson
Posted: 03/23/13 12:56pm Link  |  Print  |  Notify Moderator
Not even close. Check your trucks payload, probably 1400# or less and the pin weight of the trailer will exceed that by several hundred pounds before you load anything. The 1230# hitch weight they are giving you is a joke. More truck or less trailer. Good Luck! [emoticon]
The Texan
Home ... Toquerville, UT .. Summer ... Cascade, ID
Posted: 03/23/13 01:10pm Link  |  Print  |  Notify Moderator
Will it pull the 5er, you better believe it will, BUT will the truck handle the weight, NO. The first and biggest problem is going to be the payload to carry the pinweight.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
3LittleDucks
Canada
Posted: 03/23/13 01:18pm Link  |  Print  |  Notify Moderator
I am not a towing expert, but have been told that 1/2 tons should not pull 5ers. I could be wrong, and there could be exceptions, but I don't like to push the envelope with towing.
2008 Nissan Armada TV
2007 Trail Cruiser 21RBH HTT
The Texan
Posted: 03/23/13 01:25pm Link  |  Print  |  Notify Moderator
The newer ½ tons are very capable of towing 5th wheels and the manufacturers give their blessing by approving the practice. BUT, it must be one that is "properly" equipped from the manufacturer. That is one reason we bought the model we did, it is approved for and capable of, towing a properly sized 5er.
MPI_Mallard
Morpeth Ontario,St. Cloud Florida
Posted: 03/23/13 02:22pm Link  |  Print  |  Notify Moderator
I really wonder why they don't have laws set out to stop people from doing this kind of thing,it's an accident waiting to happen,,,on the same roads we all drive on.
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blücher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
45Ricochet
North Idaho
Posted: 03/23/13 02:37pm Link  |  Print  |  Notify Moderator
BTDT and even after installing more spring pak, getting tow mirrors, and tuning the 5.9L engine it still lost the tranny after a couple of years.
Almost the exact same 5er also.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
