RV.Net Open Roads Forum: 255 70R 22.5 H 16 PR MICHELIN OR GOODYEAR?
 > 255 70R 22.5 H 16 PR MICHELIN OR GOODYEAR?
GULFSTREAMER37
WATERBURY
Posted: 03/26/13 07:16pm Link  |  Print  |  Notify Moderator
I purchased my Gulfstream last Oct, getting ready for a trip to Nashville TN in a couple weeks, Looking things over I checked the Date on my Goodyear G670s they are 7 years old this Month but only 10K miles on them, they look Very good, No dry rotting, no cracking, no bubbles Tread is Smooth and Flat no rivering.
I have learned alot reading these forums regarding tires on RVs and It appears I am at a crossroad, Replace them or risk a blow out or worse.
I don't mind replacing them for the best quality tire I can buy in my size.
My size 255 70R 22.5 H 16PR seems to somewhat limit my choices.
Plus Local Availability and Tire shops willingness to find recently date coded Tires in a matching set has become a Challenge.
I located G670s close by but they are already nearly 2 Years Old Code 4011
Petes Tire barn (who does not sell Goodyear) is willing to get me less than 3 month old Michelin XZEs and Tells me this is the tire he runs on his RV
And they also have a wheel Referbishing program for 38.95 a wheel where they get sandblasted Zinc coated and Powdercoated white or Black, and they have pallets of them in stock, Which is enticing since my wheels are dirty and a bit rusty in spots.
I have read a lot about Michelin tires Cracking so this has me a bit concerned about spending 3500.00 on tires.
I suppose I can keep looking for Goodyear, I have only tried one dealer.
So the Dilemma, Michelin XZE or Goodyear G670??
2007 GULFSTREAM CRESCENDO 37 MODEL-378 FRED CUMMINS 5.9 300 HP ALLISON 2000MH 5 SPEED, BANKS DIESEL TUNER WITH IQ 2.0 SYSTEM FOR UP TO 85 RWHP AND 203 RWTQ GAINS.
rv2go
Fulltime 15 yrs (Knoxville, TN).or someplace else
Posted: 03/26/13 07:35pm Link  |  Print  |  Notify Moderator
I run Michelin 255 80R XZE's on my Journey and am real pleased with them.
The XZE is an truck tire and is more readily available than some other tires. It does have firmer sidewalls and may ride a little firmer than an RV tire.
If you are a FMCA member, they have a discount program on Michelins.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
randallb
On the road
Posted: 03/26/13 07:48pm Link  |  Print  |  Notify Moderator
I sold my 08 HR just prior to it needing tires. The front G670s never knew if they were round or square. Some days they were smooth as glass and other days square. There was no rhyme nor reason to the shake. They also were showing signs of rivering. I would recommend the Michelins. I have run Michelins on 90% of the vehicles I have owned and never had a bad experience. Buy the Michelins, the sidewall cracking/zippering has been cured.
Randy
GULFSTREAMER37
WATERBURY
Posted: 03/26/13 07:50pm Link  |  Print  |  Notify Moderator
Ride Quality is Important to me for sure, there are enough things rattling I don't need to exaggerate the rattles.
Thank you.
Big Katuna
Deland, FL
Posted: 03/26/13 09:17pm Link  |  Print  |  Notify Moderator
Having had both, no question in my mind; go with the (newer) Michelins.
My Kharma ran over my Dogma.
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 03/26/13 09:23pm Link  |  Print  |  Notify Moderator
+1
FIRE UP
Lake Havasu City AZ
Posted: 03/26/13 10:53pm Link  |  Print  |  Notify Moderator
Gulfstreamer37,
There seems to be this magical time clock of "7 years" and, the minute it turns seven years, people panic and reach for their wallet. Well, I'm certainly not going to tell you to keep them, or can them, that's up to you. I've ran tires up into and past 8 years old without any issues what so ever. Just exactly how many RV tires have heart attacks at age seven, I have no clue.
I'm presently running the Michelin XRV 255 80R 22.5 and, they've performed flawless up to date. A while ago I read on here a poster stated Michelin tires need no balancing. Well, I guess all those weights on mine, that are on alloy rims, are useless. But, that's beside the point here.
Anyway, I've not had to locate up to date tires lately for our rig 'cause ours, all six of them, are dated, 3410, so I don't know how hard it is to get the latest production date tires, especially if you're looking for a specific size. But, I'm certain I would not pay for and have installed, tires dated anything 2011. I'd definitely look around or, travel to other tire suppliers.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
JR45
Warren/OR/USA
Posted: 03/26/13 11:37pm Link  |  Print  |  Notify Moderator
I just got a set of Michelins 295/80R22.5 through FMCA and they are 6 weeks old when installed.
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
GULFSTREAMER37
WATERBURY
Posted: 03/27/13 06:58am Link  |  Print  |  Notify Moderator
I may run the Goodyears the rest of this year and see how it goes because upon inspection they do look very good.
And continue to research my options, and I may consider the next size up to increase my range of options.
I am glad to hear that Michelin has fixed the Cracking problem, I read a bunch of Old threads and that had me concerned.
I do want the Best Ride Possible, least rolling resistance, highest quality tire I can find, I plan to keep this rig a very long time.
Thank you all for your responses, Keep them coming.
* This post was edited 03/27/13 07:47am by GULFSTREAMER37 *
Bob & Ann
North AL
Posted: 03/27/13 07:02am Link  |  Print  |  Notify Moderator
X2 on the FMCA pricing. We run the older style Michelin that we bought exactly a year ago. We like them and do not feel the ride is too hard.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17}
Chihuahua - Lola
Autumn-Red Poodle
Tiffin 2014 40 QBH Phaeton
Freightliner Chassis
Cummins ISL 380 HP/150 Torque
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2014 Jeep Wrangler Unlimited Toad
Demco Dominator & Airforce One
