RV.Net Open Roads Forum: Trouble shooting Norcold 1200 with Amish Cooling unit
 > Trouble shooting Norcold 1200 with Amish Cooling unit
Smitty77
OnDRoad
Posted: 03/30/13 05:02pm Link  |  Print  |  Notify Moderator
Looking for some input on how to trouble shoot a warm refrigerator, with a cold freezer.
Background
> We wanted to retain LP capacity, but had concern with the Norcold recall solutions for the 1200. So about two years aro, we ordered the RV Cooling Unit Amish Unit (Thank you David Force), and had it installed on our schedule. (Tossed in some extra rear cooling fans, smoke detector and SS30 extinguisher in the rear of the cabinet.)
> The unit has run well for us, and we found that setting 5 would usually support our usage needs.
> I've had the RV in the shop for a few things getting prepped for a trip. One of these was adding a stubbed out LP line to feed our Heat Buddy. This is spliced into the LP line that feeds the fridge, and stubbed out under two drawers beneath the 1200. Had this work done in January.
> I just started the fridge up as I like to do every few months, along with other normal maintenance and excercising of the various systems in the coach.
Problem
I've had the fridge running for 6 hours, off of LP, on setting 6. As always, the LP took two or three times for the gas to flow, then started up the burner as normal.
The freeze has cooled down well, but if I'm getting any cooling in the fridge, it's not much. Inside temp is 60 degrees. The cooling fins feel cool to the touch, but not cold. I suspect all of the cooling I'm getting in the fridge, is falling in from the freezer area.
Again, I can hear the LP burner burning. The freezer is cooling well, have not checked the temp, but feel right after 6 hours. The freezer being so cool, makes me think it has nothing to do with the now two year old cooling unit(?).
I see normal lights of on the controls.
What trouble shooting tips can some of you share with me. Can any of you think of anything down in the burner area that may have been accidentially impacted by the tech installing the stub out of the LP line for me? (The burner burning, made me think not... But, what the heck do I know[emoticon]!).
Appreciate any and all suggestions. I've set it up to 8, and going to check it in another two hours.
TIA - and Happy Easter to you all,
Smitty
chili's trip
Full time
Posted: 03/30/13 05:35pm Link  |  Print  |  Notify Moderator
It is possible the tech installing the connection caused a piece of Teflon tape to be entered into the gas line which is restricting the flow to the burner. A lower than spec flame level can cause your symptoms. (on another note the Mr Heater buddy is not designed to work on low pressure LPG.) Good luck!\
Jack H
2005 Fleetwood Bounder 32W 8.1.
2009 Honda Fit Sport
sunkatcher
Fulltimer
Posted: 03/30/13 05:41pm Link  |  Print  |  Notify Moderator
After 6 hours there should be FROST on the freezer plate not just cool in the freezer. Sounds like the coil is not working. Can you plug in to electric?
masa4u.com
dougrainer
Carrolton, Texas
Posted: 03/30/13 05:43pm Link  |  Print  |  Notify Moderator
1. 6 hours is not enough
2. wait 24 hours then see what happens
3. There is no way the cooling of the freezer can drift down to the bottom area
4. The 1200 series has NO CO system. IF the refer is failing to do a normal cool down cycle, the NO CO would come on and stop refer operation
5. WAIT 24 HOURS!!!! Then worry if it does not cool in the bottom.
6. Setting on a colder temp will NOT make the refer cool faster. Doug
mdprince
Santa Clarita, CA
Posted: 03/30/13 06:42pm Link  |  Print  |  Notify Moderator
Sounds like how mine was acting last summer on a trip. Came home to find out that both cooling fans were not working. Had them replaced and it works like new again.
2006 Revolution LE 40E
2004 Jeep Rubicon Toad/Brake Buddy or
20' Toy Trailer/Quads 'n Dirt Bikes
Smitty77
OnDRoad
Posted: 03/30/13 06:52pm Link  |  Print  |  Notify Moderator
I'll let it run until at level 8 a bit longer, then check the temp. I'll also get a temp reading in the freezer too. I'll plan on turning it off tonight, and then also run a test in the AM with the electric source.
Restricted LP flow? Suppose it is possible, should have run a check before bringing the coach home[emoticon]!
On the Heat Buddy. We have the both the Big Buddy and the Portable Buddy. So we have different options. Per the Heat Buddy manual, we can go with either filtered HP, or regulated LP feed. I appreciate the caution, and will call and talk with Heat Buddy before testing the unit with the new stubbed out line.
Thanks for the info on the 1200, still a bit puzzled[emoticon]! Perhaps I have not let it run long enough...
Best to all,
Smitty
Ivylog
Blairsville, GA and WPB, FL.
Posted: 03/30/13 06:55pm Link  |  Print  |  Notify Moderator
Not sure 6 hours is long enough. Need to know the actual temp of the freezer section.
04 Monaco Dynasty 42' quad slide
How I tow.
Towing a Prius without a dolly
Where am I?
How I spend the winter.
lfeather
Titusville, FL
Posted: 03/30/13 07:03pm Link  |  Print  |  Notify Moderator
Agree, and is the coach level?
Larry, Debbie & Max the Pug
USAF Retired
2014 Itasca Reyo P
2016 Subaru Forester 2.5i 6 speed manual transmission
larry cad
ohio
Posted: 03/30/13 07:58pm Link  |  Print  |  Notify Moderator
IF the freezer continues to get colder, and the frig remains warm, and if the fans are working, you probably have a bad cooling unit. Those seem to be typical symptoms. Sorry
Our Travel Blog
chili's trip
Full time
Posted: 03/30/13 08:47pm Link  |  Print  |  Notify Moderator
The best test is to check on electric. IF it cools on electric the cooling unit is fine. I have experience with a Norcold with the same symptoms that needed a new burner. The flame was about 50% of normal. Good luck!
Jack H
