RV.Net Open Roads Forum: RV bathroom faucet issue
 > RV bathroom faucet issue
scarpi
Phoenix
Posted: 04/13/13 04:54pm Link  |  Print  |  Notify Moderator
Hi all. I have a PW Excel TD and I would like to replace the bathroom faucet. It is the type with the shower diverter. The problem is that the faucet arm is too short. It is very close to the side of the sink and we can hardly get our hands between the spout and the side of the sink to wash our hands etc. Is there a four inch standard faucet with a shower diverter that has a longer spout that would make it much easier to wash your hands?
Thanks all.....Don.
charles
Ohio
Posted: 04/13/13 05:37pm Link  |  Print  |  Notify Moderator
Don, The same question was asked a year or so ago and I believe they found one to fit at Lowes or Home Depot.
Nick
2012 Pleasure-way Excel TS
CA POPPY
Santa Clarita, CA, USA
Posted: 04/13/13 10:00pm Link  |  Print  |  Notify Moderator
Thanks all.....Don.
Yes, that faucet is something we replaced after our first trip with our Excel TD. Interesting, how such a small detail can be so annoying. I will have to ask Bud where he got it, but we replaced with a faucet that allowed a connector to one of those flexible dishwashing hoses you used to see in stick houses. That way, with the hose attached, we can get the temp adjusted and then take a quick shower and the on/off is right there, fast to switch. And yes, the faucet throw is longer, making it much easier for hand washing. (the hose is left off when not needed.) I am sure we got the supplies at Lowe's or Home Depot, but will get back to you on the details.
Judy & Bud (Judy usually the one talking here)
Darcy the Min Pin
2004 Pleasure-Way Excel TD
California poppies in the background
CA POPPY
Posted: 04/14/13 07:12pm Link  |  Print  |  Notify Moderator
Okay, I debriefed Bud and the faucet we installed is a Delta, similar to THIS ONE but in chrome. The goose neck spigot not only provides more room to wash your hands but it also makes hooking up the shower hose easier. After it was installed, we replaced the original strainer with a "quick disconnect" and added a shower hose/shower head combo that came as a set from the plumbing dept at our local hardware store. The shower head has a button that slows the flow to a trickle and gives you a chance to turn off the faucet handles. The turn off/trickle also gives you a chance to shampoo your hair and have the water temp stay the same when you turn it back on to rinse. This is one of the best mods we've made to our Excel TD. [emoticon]
CA POPPY
Posted: 04/14/13 07:21pm Link  |  Print  |  Notify Moderator
One other bathroom issue while we're talking PW Excel TD. On our first long trip, somebody (name withheld to protect the guilty) left a wet washcloth draped over the front of the sink overnight. In the morning, the countertop laminate had started to separate. [emoticon] Luckily, we happened to have a wood clamp with us. We put a dry washcloth over the edge and applied the wood clamp and left it there for a day or two. Whew! You can't tell that it ever happened. I do kind of envy the Corian countertops the newer units have.
scarpi
Phoenix
Posted: 04/15/13 09:32am Link  |  Print  |  Notify Moderator
Thanks all for the comments. We love our PW but that bathroom faucet is something else. I bet the designers who thought of that did not really try to use it to wash their hands. I will try your fixes thanks again.....Don.
CA POPPY
Posted: 04/15/13 10:44am Link  |  Print  |  Notify Moderator
Agree. Bud had the original faucet in the garage and I was shocked (again) when I looked at it, to realize it is thin plastic with small plastic handles. Didn't seem like the well-known PW quality.
scarpi
Phoenix
Posted: 04/19/13 12:14pm Link  |  Print  |  Notify Moderator
Hi all, well as suggested, I bought a faucet at Home Depot that has a longer spout (about 5 inches) instead of the original spout that was only about 3 inches long. The new spout also has a high arc unlike the original straight one so we will be able to wash our hands easily. I also bought an aireator to replace the one that came with the new faucet and screws in directly to the spout. This new aireator has one end that plugs into a quick disconnect. I then bought a quick disconnect that is attached to the shower hose. This quick disconnect then plugs directly into the new faucet aireator when I want to shower. Thanks to this forum and members for the way to solve this problem. I plan on installing this over the next couple of days. Thanks all.......Don.
PSW
Oklahoma City
Posted: 04/19/13 05:18pm Link  |  Print  |  Notify Moderator
After reading this post regarding faucets, I took a look at the kitchen faucet in our Roadtrek. I have no knowledge about PWs, but man I gotta tell you, I don't think I have the courage to ever try to replace the faucet in my RT. Simply put, with an undermounted sink and a Corian countertop, I don't think a fly could hardly get up in there to do the job. I did have a small leak that had started from the top of the thing, but I was able to tighten it and shut that down completely. The only way I could figure out how to do the under the counter replacement would be to cut out a couple of shelves that are in the lower part of the cabinet and are put in there in a slot on either side, a sort of tongue and grove type installation. Then, I think I would have to take the drain pipe out to make room to get my hand back in there and would probably have to use a mirror and light to see what I was trying to do.
I replaced a faucet in a Class C once and it was easy as pie. All of our Bs share a smaller size and less work space on just about everything. I am sure glad your PW job was doable. Roadtrekers, beware!!
PSW
2013 Phoenix Cruiser 2350
2014 Jeep Cherokee behind it
and a 2007 Roadtrek 210P for touring
scarpi
Phoenix
Posted: 04/23/13 01:32pm Link  |  Print  |  Notify Moderator
Well I finally replaced that bathroom faucet with the parts I previously mentioned. The new faucet works great, no leaks and we can easily wash our hands because the new faucet spout is higher and longer. For showers I just plug in the shower hose to the faucet spout with the quick disconnect! Thanks for the tips all....Don
