I currently tow my 94 Chevy 4X4 auto by simply putting the transfer case in neutral, the transmission in park and the key in the on position so sterring wheel can turn. I towed like this for 75000 plus miles. I am looking into buying a new chevy silverado 4x4 with automatic transmission. Can I tow this new truck?
I would say contact your local Chevy dealer. The service advisor will likely say NO !! But he might find out for sure whether you CAN or NOT. He will certainly NOT ADVISE it though. That doesnt mean you CANT however.
Tim-DW(Kathy)
12 Chevy Sonic DD, 03 JEEP GRAND CHEROKEE, 2001 Jayco KIWI If a "nightmare" is considered a dream-then I am living the dream
I used to tow an '05 Silverado with the manual transfer case. I now tow a '13 Avalanche. It has the electronic transfer case. There is a simple procedure in the owners manual for putting the transfer case in Neutral. I understand the Silverado is the same.
Millennium Prevost 2006
2013 Chevy Avalanche Black Diamond
HD 2015 Ultra Limited Low (Mine)
HD 2016 Triglide (DW)
Cruiser Caddie motorcycle lift and 24' Stacker
just check the owner's manual for requirements to tow 4 down. that is the only "legit" source of information, at least until it is out of warranty.
bumpy
Yes, the proper procedure is in the owners manual. However, they no longer put the N on the selector switch, so you can't tell by looking. On ours, you twist and hold the selector switch all the way to the right, till a "red" light illuminates. All other lights on the switch are amber. Also, no more leaving the key in the ignition, as they removed the steering lock in the early 2000's. Now days, just pull the key, lock the doors and put the key in your pocket. Great toad vehicle.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever" 2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back. Where the wheels are stopped today
The Texan wrote: Yes, the proper procedure is in the owners manual. However, they no longer put the N on the selector switch, so you can't tell by looking. On ours, you twist and hold the selector switch all the way to the right, till a "red" light illuminates. All other lights on the switch are amber. Also, no more leaving the key in the ignition, as they removed the steering lock in the early 2000's. Now days, just pull the key, lock the doors and put the key in your pocket. Great toad vehicle.
Thank You. Im not the OP but it is nice to know this. Thanks Again
