RV.Net Open Roads Forum: Class A Motorhomes: "Duck Coat" roof coating
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > "Duck Coat" roof coating
Jerry B
Lake of the Ozarks
Posted: 04/20/13 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
RoadXYZ wrote:
Jerry B wrote:
Anyone tried this?
http://duckcoat.com/
Who suggested you do this ?
I saw it at Menards. It can be used with pooling water and is not water soluable. I'm going to try it on a EPDM roof on my wifes art studio. If I like it, the RV is next. Appears much easier to use than the two part "Liquid Roof" EPDM product.
Jerry B
Mobile Suites 36TK3
havasu
Lake Havasu
Posted: 04/21/13 11:26am Link  |  Quote  |  Print  |  Notify Moderator
It's just another Elastomeric - we use it on the roofs of the mobile homes in the desert and there are probably a dozen different suppliers including Henrys and range from $60 a 5 gallon drum to $160 for the top notch stuff.
It doesn't chemically bond to the surface - just a mechanical bond so surface needs to be well prepped. It forms a thick 'rubber' skin that is 100% waterproof but water can creep underneath it from splits or edges.
Typically we recoat every 2-3 years in the desert.
It should work on an RV as it remains flexible - just make sure the surface is clean and pretreat any cracks or leaks with Dicor sealant first and let it cure before applying.
Doc Eagle
South Carolina
Posted: 04/27/13 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
We put the white liquid RV roofing on last weekend. Little prep work and four hour work time, squeege it out and smooth out with a roller. Goes over a rubber roof nicely, guess that is similar stuff, our roof was 20 years old and in pretty decent shape. Just wonder the price on that stuff.
1993 Fleetwood Flair 22D "Cat One"
USN(RET)
Fire Captain(Career)
Fire LT(Volunteer)
clc530
Home
Posted: 05/23/13 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
SureCoat Roof Systems for Recreational Vehicles has anyone used his?
