RV.Net Open Roads Forum: Fifth-Wheels: B & W Companion Lube Plate use question
 > B & W Companion Lube Plate use question
E=mc2
Orangevale California
Posted: 05/01/13 10:24am Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
I am still new to fifth wheel towing and I had a question regarding the use of a lube plate and a Companion. I currently run the Companion with the standard 1/4 inch Lube plate, My question is should I be running the 1/8 inch lube plate instead. The reason I ask is the jaws on the hitch are pretty much the same size as my pin. Sometimes it doesn't want to unhitch real easy and I was wondering if that is the cause. If you have a Companion do you use a lube plate? Standard thickness or the thin one? Ever have trouble unhitching sometimes?
Thanks
2007 GMC Sierra 2500
2009 Weekend Warrior Superlite
B&W Companion
2006 Arctic Cat 650 H1 (x2 His and Hers)
An Awesome Family!
fj12ryder
Platte City, MO
Posted: 05/01/13 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I use the standard lube plate with no issues. If there is any pressure on the pin it can be touchy to get the hitch to disengage the jaws. I have had to move the truck to release some pressure from the hitch before I could get the hitch to release.
Do you have an aftermarket pin? Like a Mor-Ryde or one of the air pins?
Howard and Peggy
"Don't Panic"
E=mc2
Posted: 05/01/13 10:46am Link  |  Quote  |  Print  |  Notify Moderator
No aftermarket pin, just the lippert that came with the hauler. I probably just need to get used to it and find the sweet spot for it to let go.
Thank you!
ependydad
Here and there
Posted: 05/01/13 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Same here- standard pin and regular lube plate.
2013 Sabre 36QBOK
2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
bogart661
Canyon Country, CA
Posted: 05/01/13 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure that the last motion with the truck is in reverse, if you have pulled forward it will put pressure on the jaws making it hard to unhitch.
Vinnie and Chris
2013 2WD Chevy Silverado LTZ 3500HD Crew Cab Short Bed Duramax/Allison Reese R16 Slider
2014 Crossroads Cruiser Patriot CF305SK
fj12ryder
Platte City, MO
Posted: 05/01/13 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly so.
laknox
Arizona
Posted: 05/01/13 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
Exactly so.
Or neutral, if you're on fairly level ground. I can occasionally have some tightness when unhitching on unlevel ground. On time, when we were at our usual boondock site, I'd run over a partially-buried rock that was causing the FW to pull to one side and I had to back off it to get the jaws to unlatch easily. I probably could have forced the issue, but it was just easier to raise the legs and back up a foot.
FWIW, I use the 1/4" plate with my Companion, with few problems.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 60 Year Member
FlatBroke
CO/AZ
Posted: 05/01/13 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I had a Hensley 1/8 disc on my old trailers Lippert pin box and it worked pretty well but it broke when I took it off. Our new acquisition has a TraiAir pin box and with a 1/4" lube plate you can not see a gap when you use the Companion. Hensley wants $20 and $15 freight for a new one. What a rip off compared to the standard disc. I am about to slather on the grease or see if I can make one out of an old plastic bucket.
Hitch Hiker
"08" 29.5 FKTG LS
Cummins12V98
on the road
Posted: 05/01/13 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
I did buy the Hensley 1/8" plate because it was hard to tell when the pressure was off so I could release the handle. It does work much better.
If you want to save some money cut the bottom out of a 5 gallon bucket and the center ring on the bottom is the correct size to cut out along the circle.
The Hensley did not fit tight and kept slipping down so I laid it on a hard surface and hit the edge of the hole in the middle of the plate with a hammer and now it fits tight and works great.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
FlatBroke
CO/AZ
Posted: 05/01/13 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Just got done butchering a five gallon bucket. Is even thinner than the Hensley and seems real flexible. Looks like I am good to go.
