RV.Net Open Roads Forum: Class C Motorhomes: Brake Adjustments Ford E450 Motorhomes
 > Brake Adjustments Ford E450 Motorhomes
jdog
Northern California
Posted: 05/08/13 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
How often or what milage do the brakes need adjusting?
BruceMc
Oregon - Willamette Valley
Posted: 05/08/13 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Ours has disc brakes on all 4 corners - no adjustment needed until replacement time. So far, we have 40K on the clock and the brake pads still look new.
If you had drum brakes, they should be self-adjusting.
Every time you back up and step on the brakes on vehicle with drum brakes, you are adjusting them.
'16 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
Previously:
'00 Four Winds 26Q Class C (Ford E350 V10)
'96 Kit Sportsmaster 212f Fifth Wheel/'93 GMC Sierra K2500
'91 SunLite poptop truck camper
and the first: a Wildernest flip-top canopy.
crawford
Dandridge Tenn.
Posted: 05/08/13 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
also mine disks all the way around no adjustments needed[emoticon]
Change from a c class to a A class Georgetown 07 triple slide
super_camper
Ontario, Canada
Posted: 05/08/13 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Adjustments haven't been necessary but we have had maintenance done just to inspect and lubricate. We found the breaks squeak a lot if you don't keep up with maintenance.
Momboy007
Posted: 05/08/13 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
What type of maint. do you recommend, My 2006 E-450 has 20K miles and I have not touched them, what do you recommend?
Rick
crawford
Dandridge Tenn.
Posted: 05/08/13 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I would flush out old brake fluid with new , also I would go for the transmission flush some would say drop pan but you never get all the old fluid that way.
Beverley&Ken
Tottenham,Ontario
Posted: 05/08/13 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Have calipers/slides cleaned and lubricated. Should prevent a seized caliper at the most inopportune time.
When we had ours done last year, they did a chemical test (for water/impurities etc) and said that the brake fluid was OK. They did find that the brake pads were dried or defective and large pieces were flaking off. Only minimal wear after 30000 miles.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Paoli
Quesnel BC
Posted: 05/08/13 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Does a regular Ford dealer take these motorhomes in for service or do you guys go to a special RV facility?
Beverley&Ken
Tottenham,Ontario
Posted: 05/09/13 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the individual dealer. Our local Ford dealer had a small building and could not get a large vehicle inside.
We were lucky to find a KAL Tire associate store close to us that have the size and facilities to work on large vehicles, cars to large trucks.
An RV dealer could do the work, if they have MH facilities (mechanics etc). The RV dealers near us only sell trailers and will not touch MHs.
harley-dave
ummm, where are we again..
Posted: 05/09/13 07:23am Link  |  Quote  |  Print  |  Notify Moderator
We took our 31C Winne to a regular Ford dealer. They handle delivery trucks so it's no problem to do a similar size RV.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
